Justin Raza Posted August 26, 2021 Posted August 26, 2021 Could do with some help please, background, drove daughter 20 miles to catch train ,on return journey oil light came on, checked oil it was ok but added a splash and continued home, parked car and left it for two days. Checked the oil two days later and it was about the same( minus cooling ) about three quarters up the marks on dip stick. Went to start car and it will crank but not fire at all. As per suggestion from somewhere I changed the coolant sensor (£6 worth a try) but still no start up. Scanned the car with a cheap vag unit and the Only code it throws up is p0322 , where to next?
Brian74656 Posted August 26, 2021 Posted August 26, 2021 1 hour ago, Justin Raza said: Could do with some help please, background, drove daughter 20 miles to catch train ,on return journey oil light came on, checked oil it was ok but added a splash and continued home, parked car and left it for two days. Checked the oil two days later and it was about the same( minus cooling ) about three quarters up the marks on dip stick. Went to start car and it will crank but not fire at all. As per suggestion from somewhere I changed the coolant sensor (£6 worth a try) but still no start up. Scanned the car with a cheap vag unit and the Only code it throws up is p0322 , where to next? Error Code P0322 is defined as Ignition/Distributor Engine Speed Input Circuit Low. This code applies to all spark ignition engines, such as Audi
