Matthew Hardie Posted September 16, 2021 Posted September 16, 2021 Hi All, how can I find out what the part code is for the front drivers side door wiring loom on my car without removing the old one. I have an A4 B7 3.2 Quattro S line.
Stevey Y Posted September 16, 2021 Posted September 16, 2021 9 minutes ago, Matthew Hardie said: Hi All, how can I find out what the part code is for the front drivers side door wiring loom on my car without removing the old one. I have an A4 B7 3.2 Quattro S line. Hi to be totally accurate the best way is remove the door card and read the coding tags on the wiring as they all differ according to which options were available at that time worse ways you will have a few screws to remove but won't have to remove the loom before you buy a new one, chances are any problems you may have could be just down to a broken wire in the Flexi boot between the door and the body. Steve.
