arron1995 Posted September 28, 2021 Posted September 28, 2021 so yesterday after work i started the car up, started to accelerate and all of a sudden this sort of fast clattering noise occured, i pulled over straight away and opened the engine bay and started to rev the car, the noise could not be demonstrated. As i set off again and put my foot down the noise came back, the noise gets better as the engine warms up, ive checked for fault codes and nothing came up, ive checked injector deviation and they all look fine, the only thing thats happened since the noise has started is ive put in asda fuel (usually use shell) ive attached a video, its best heard around 15 seconds, has anyone got any ideas as im stumped? also noticed at the back of the engine it smells of either fuel or exhaust gasses, but cant see any smoke. video-1632832497.mp4
Stevey Y Posted September 28, 2021 Posted September 28, 2021 Hi it sounds a bit like a DMF problem my car is doing the same until warmed up assuming its a manual, if its DSG it could well be the same thing and that oily smell is knackered gearbox oil vapour exiting the breather which should have a green/black plastic cap on it that sits just behind the engine on top of the gearbox its a rubbish design as the plastic deteriorates and it falls off, replaced mine twice now, Audi want £6.00 a unit Vs two for £5.00 off of eBay. Steve.
cliffcoggin Posted September 28, 2021 Posted September 28, 2021 I don't recognise the noise, but it's odd that the clatter rate seems to be constant even when the road speed increases.
arron1995 Posted September 29, 2021 Author Posted September 29, 2021 14 hours ago, Stevey Y said: Hi it sounds a bit like a DMF problem my car is doing the same until warmed up assuming its a manual, if its DSG it could well be the same thing and that oily smell is knackered gearbox oil vapour exiting the breather which should have a green/black plastic cap on it that sits just behind the engine on top of the gearbox its a rubbish design as the plastic deteriorates and it falls off, replaced mine twice now, Audi want £6.00 a unit Vs two for £5.00 off of eBay. Steve. Today I noticed that the noise doesn’t occur in 1-2nd gear, only 3rd and onwards and only while accelerating, I’m wondering if it is the injectors but at the same time the deviations are fine during idle.
Mizzk997 Posted July 29, 2024 Posted July 29, 2024 Hiya mate, i’m getting the same sound on my quattro a3, did you ever manage to get it sorted??? No one else is talking about this online… changed rear drive shafts both sides still persists.
SooTam Posted August 22, 2024 Posted August 22, 2024 On 7/29/2024 at 1:05 PM, Mizzk997 said: Hiya mate, i’m getting the same sound on my quattro a3, did you ever manage to get it sorted??? No one else is talking about this online… changed rear drive shafts both sides still persists. Hi, wondering if you got an answer to what the problem was as my Audi A3 is doing exactly the same.. thanks
