frenchhr Posted October 13, 2021 Posted October 13, 2021 2007 Audi Avant 3.2l with 41 k on the engine. The first pic is the reading after I changed both upper timing chain tensioners. The specs were off so I adjusted bank 1 this weekend and the numbers went down, and the engine is stronger. The P0366 CEL still comes on but it takes more driving though. What are the correct readings for a proper operation? I’ve attached photos of what the exhaust came looked like before I adjusted them by pulling both cams out with the timing tool. If the numbers are still off I’m at a loss. Both banks are perfectly lined up and I followed all procedures. Could it be the ECM, bad tensioner, or cam phaser. Thanks
