Help needed from a new member,does anybody know if the turbo off an 07 2L tdi 140bhp with dpf, will be a straight swap for the turbo on an 05 2L tdi 140bhp without a dpf on….. thanks in advance.
Hi have look on a website called Zap 7  and get the part numbers, alternatively ask a turbo specialist they are normally pretty helpful. I strongly suspect they are the same but best advice is check twice do once.
