Robin Pounder Posted October 31, 2021 Posted October 31, 2021 My 2009 1.8TFSI has started to play up. Basically I can't lock it without the alarm going off. Using either the lock button on the fob or the key itself, the doors lock as they should, but a few minutes later, and the length of time is variable, the indicator lights start flashing accompanied by a low volume persistent "beep", not the loud alarm siren though. I disconnected the battery to see if that would reset something, but to no avail, and which in turn has led to other problems, namely the illumination of several warning lights on the instruments. Not sure if this might be relevant, but prior to this fault rearing its head the emission control system warning light appeared. Any ideas? Robin
cliffcoggin Posted October 31, 2021 Posted October 31, 2021 The most likely culprit, amongst several, is the car battery is dying. 1
Stevey Y Posted October 31, 2021 Posted October 31, 2021 HI, Clifford is right it may well be the battery in which case replace it and while they are coding the battery the new battery get them to clear any faults, the emissions light may well be a dodgy oxygen sensor which is an easy cheap fix. Steve.
Robin Pounder Posted November 5, 2021 Author Posted November 5, 2021 Thanks guys, good call. I'll be booking it in tomorrow. I'll follow up on this forum just for others benefit. Robin 1
Robin Pounder Posted November 5, 2021 Author Posted November 5, 2021 Turns out the drivers side central locking mechanism was faulty. New one fitted, problem sorted! 1
Stevey Y Posted November 5, 2021 Posted November 5, 2021 2 hours ago, Robin Pounder said: Turns out the drivers side central locking mechanism was faulty. New one fitted, problem sorted! Hi glad its sorted out, just goes to prove electrical problem are a real can of worms. Steve.
