Biltub Posted December 10, 2022 Posted December 10, 2022 Hi Jim Mine is the same except the nav database which is 2022
larsl Posted December 26, 2022 Posted December 26, 2022 Hello, We've bought our 2020 A3 sportback in March, second hand audi approved, and have noticed the same issues since September. Firstly the MMI would go black on certain locations, but would still work when you started the car later. Still we went to our local Audi dealer with it and they said there was a bigger fault behind the MMI in the control unit. They completely shut off the screen so we couldn't use it anymore. A new part has to be made back in Germany to fix the problem. They only have no idea when that will be. They get no date or period back from Germany so they can't really do much either. Out of procedure, the factory's response was January first 2031!? Luckily we have a replacement car from the dealer, but it's still annoying not to know when you get your own car back. Anyone else currently waiting without a prospect?
mrapriliafalco Posted June 17, 2023 Posted June 17, 2023 Mine has being doing a software update since Feb!! took to Audi and they did a 10 hour software update seems to be fine now
DNeault Posted July 6, 2023 Posted July 6, 2023 Looks like I have a new issue with this then. My 2023 S3 MMI, works fine ... sort of. I tried a "on demand" function through the Audi App, for only 1 hour, and when I discontinued it, and car went back to default, the MMI turned my S3 menu's, to A3 menu's. Lost all my additional S3 screens, and MMI pad, only functions for volume now, none of the "button" features work. VW has tried to fix remotely, as least 6 times now, no effect. Dealer has no procedure to fix this, so car is in "limbo". Filed to force VW to take back car, for this, and other issues (no coolant hose clamps, after I picked it up, car only lasted 20 minutes). Hope this helps someone know, there not alone in there issues 🙂
