Darylbob Posted November 4, 2021 Posted November 4, 2021 Hi folks just checking if anyones had the window switch unit out on one of these.. as the drivers side window has just given up the ghost, it's just the drivers side window that's not working that's what's making me think it's the switch, it started intermittently not responding, and heard no binding noises or slow movement to suggest it might be the mechanism. Any help would be much appreciated 👍
Steve Q Posted November 4, 2021 Posted November 4, 2021 Definitely worth changing the switch especially if the other windows work off the driverside
Darylbob Posted November 4, 2021 Author Posted November 4, 2021 Grand thought this might be the best place to start, have you ever swapped one out before?
cliffcoggin Posted November 4, 2021 Posted November 4, 2021 I don't have the manual to hand at the moment to check, but if I recall correctly each window motor has its own fuse.
