Hi all, hoping that someone can point me in the right direction. I have a 2007 A6 Allroad 3.0tdi and have an issue with the rear brake lights not operating correctly.
I started to have issues with the ESP light coming on along with my ABS light. Noticed that my rear brake lights were intermittently working. Afeter testing a few things I concluded that I needed to replace the brake light switch.
I did this and my brake lights worked as usual. Dash lights remained on. After 5 mins of having the engine running/driving, my brake lights come on and either stay on or flicker. Plugged in an OBD11 scanner and checked the faults. I had one for my brake light switch and one for my ABS control module.
Tried another brake light switch. Had the same results. Checked all fuses, wiring under the dash and everything appeared OK. I decided to send my ABD control module off to ECU testing in Derby and had feedback that the unit was faulty. Had it repaired, plugged back in and bled the brakes, I still have the same issue. Faults won't clear.
I've checked all usual issues, water in ECU box, replaced the brake light switch again (all genuine), checked harness wiring for corrosion, light units themselves inc connectors, bulbs, changed the clock spring, Sent the unit back to be test under warranty and still have the same issues.
Few points to note:
* my brake lights work fine when my ignition is on
* my brake lights stay on with the brake light switch disconnected
* my brake lights stay on with the switch fuse disconnected
You e done a great amount of diagnostic work. You could change the light units or the harness I appreciate the latter you found no corrosion though. Or a diagnostic check.
Yes. My diagnostics are still showing error code on the control module and Brake light switch see below. Brake light switch has been replaced again. ABS control module has come back after being test again under warranty.
OBDeleven data log
Date: 2021-11-16 12:14
VIN: WAUZZZ4F37N101026
Car: Audi A6 Allroad
Year: 2007
Body type: Avant
Mileage: 360710 KM
00 Steering Angle Sensor
Trouble codes:
No trouble codes found
01 Engine
System description: 3.0L V6TDI G000SG
Software number: 4F0910409G
Software version: 0010
Hardware number: 4F0907401C
Coding: 0011312
Trouble codes:
P1653 - Read DTC memory of ABS CM Upper limit exceeded
static
03 Brakes
System description: ESP 8.0 quattro H05
Software number: 4F0910517AB
Software version: 0040
Hardware number: 4F0614517R
Serial number: 00000000000000
Coding: 0016775
Trouble codes:
00526 - Brake light switch Open circuit
static
05 Keyless System
System description: FBSAUDIC6 ELV H31
Software number: 4F0910852
Software version: 0220
Hardware number: 4F0905852B
Hardware version: 242
Serial number: 10601100626575
Coding: 0000145
Subsystems:
System description: FBSAUDIC6 EZS H45
Software number: 4F0910131D
Software version: 0080
System description: FBSAUDIC6 IDG H01
Software number: 4F0910220D
Trouble codes:
07 Display
System description: Interfacebox H43
Software number: 4F0910732S
Software version: 5150
Hardware number: 4E0035729
Serial number: 350L$067744865
Coding: 0003002
Subsystems:
System description: Bedienteil MMIC6H01
Software number: 4F0910609E
Software version: 0060
Trouble codes:
08 Air Conditioning
System description: KLIMABETAETIGUNGH30
Software number: 4F0910043A
Software version: 0020
Hardware number: 4F2820043Q
Serial number: 00000030191009
Coding: 0001302
Trouble codes:
09 Central Electrics
System description: ILM Fahrer H17
Software number: 4F0910279K
Software version: 0240
Hardware number: 4F0907279
Serial number: 4F0907279
Coding: 0013121
Subsystems:
System description: Wischer AudiC6 H04
Software number: 4F2910113B
Software version: 0190
Coding: 0064784
System description: REGENLICHTSENSORH13
Software number: 4E0910557A
Software version: 0090
Coding: 0146221
Trouble codes:
0E Media Player
System description: MP3-Changer H44
Software number: 4E0910110E
Software version: 0390
Hardware number: 4E0035110A
Hardware version: 000
Serial number: AUZ5ZBF3128780
Trouble codes:
15 Airbag
System description: 4E AIRBAG AUDI8RH30
Software number: 4F0910655E
Software version: 0280
Hardware number: 4F0959655B
Serial number: 0037LD0M6PEP
Coding: 0013381
Trouble codes:
16 Steering Column
System description: Lenksäulenmodul H08
Software number: 4F0910549
Software version: 0230
Hardware number: 4F0953549A
Serial number: 90054063420165
Coding: 0102042
Subsystems:
System description: Lenkradmodul H07
Software number: XXXXXXXXXXX
Trouble codes:
17 Dashboard
System description: KOMBIINSTR. M73 H19
Software number: 4F0910930C
Software version: 0120
Hardware number: 4F0920981F
Hardware version: H19
Serial number: 5HS5398D6
Coding: 6253448
Trouble codes:
19 Gateway
System description: J533__Gateway H06
Software number: 4L0910468
Hardware number: 4L0907468
Serial number: 0900B06C068413
Long coding: F551BE7B703206
Trouble codes:
1E Media Player 2
System description: SG ext.Player
Software number: 4E0035785E
Software version: 0840
Hardware number: 4E0035785
Hardware version: H15
Long coding: 010000
Trouble codes:
34 Chassis Control
System description: J197 LUFTFEDER H17
Software number: 4F0910553A
Hardware number: 4F0907553A
Hardware version: H17
Serial number: 00619002589500
Coding: 0000210
Trouble codes:
37 Navigation
System description: MNS ECE H48
Software number: 4E0910887T
Software version: 1030
Hardware number: 4E0919887L
Serial number: 364LO067622211
Trouble codes:
42 Driver Door
System description: TSG FA H12
Software number: 4F0910793E
Software version: 0170
Hardware number: 4F0959793E
Coding: 0003642
Trouble codes:
46 Comfort System
System description: Komfortgeraet H22
Software number: 4F0910289B
Hardware number: 4F0907289B
Serial number: 01027044780000
Coding: 3285755
Subsystems:
System description: LIN BACKUP HORN H03
Software number: 1K0951605C
Software version: 1301
System description: Innenraumueberw.H01
Software number: 4F0910177
Trouble codes:
47 Sound System
System description: DSP-High C6 H10
Software number: 4F0910223J
Hardware number: 4F0035223G
Serial number: 00000000009430
Coding: 0000113
Trouble codes:
4F Central Electrics 2
System description: ILM Beifahrer H10
Software number: 4F0910280
Hardware number: 4F0907280A
Hardware version: ---
Serial number: 00000000300400
Coding: 0001103
Trouble codes:
52 Passenger Door
System description: TSG BF H12
Hardware number: 4F0959792E
Coding: 0003642
Trouble codes:
trouble codes found --------------------------------------------------------------- 53 Parking Brake System description: EPB CDEC0080 H04 Software number: 4F0910801C Software version: 0080 Hardware number: 4F0907801A Coding: 0000311 Trouble codes: No trouble codes found --------------------------------------------------------------- 55 Headlight Regulation System description: AFS 1 H01 Software number: 4F0910357F Software version: 0020 Hardware number: 4F0907357F Coding: 0000017 Subsystems: System description: AFS-Modul links H02 Software number: 4F0941329B Software version: 0020 System description: AFS-Modul rechtsH02 Software number: 4F0941329B Software version: 0020 Trouble codes: No trouble codes found --------------------------------------------------------------- 56 Radio System description: TUNER EU/US/RDW H42 Software number: 4E0910541Q Software version: 0620 Hardware number: 4F0035541L Serial number: 394L-067718520 Coding: 0000001 Trouble codes: No trouble codes found --------------------------------------------------------------- 61 Battery Regulation System description: J0644 BEM H12 Software number: 4F0910181E Software version: 0590 Hardware number: 4F0915181A Hardware version: 000 Serial number: 00000000167428 Subsystems: System description: von TU3 2612120060 Software number: 4F0915105D Long coding: 344630393135313035442054553332363132313230303630 Trouble codes: No trouble codes found --------------------------------------------------------------- 62 Rear Left Door System description: TSG HL H21 Software number: 4F0910795E Software version: 0050 Hardware number: 4F0959795E Coding: 0003114 Trouble codes: No trouble codes found --------------------------------------------------------------- 6D Deck Lid Control System description: ValeoHeckdeckel H21 Software number: 4F9910591 Software version: 0280 Hardware number: 4F9827851E Hardware version: H21 Serial number: E5030000B Subsystems: System description: ValeoHeckdeckel H21 Software number: 4F9910592 Software version: 0280 Trouble codes: No trouble codes found --------------------------------------------------------------- 72 Rear Right Door System description: TSG HR H21 Software number: 4F0910795E Software version: 0050 Hardware number: 4F0959794E Coding: 0003114 Trouble codes: No trouble codes found --------------------------------------------------------------- 76 Parking Assistance System description: Parkhilfe 4-Kan H09 Software number: 4F0910283F Software version: 0060 Hardware number: 4F0919283F Serial number: 06230634204696 Coding: 0200016 Trouble codes: No trouble codes found --------------------------------------------------------------- 77 Telephone System description: Handyvorb2 H16 Software number: 4E0910336M Software version: 1130 Hardware number: 4E0862335 Serial number: 00000007615203 Coding: 0010920 Trouble codes: No trouble codes found
53 Parking Brake
Coding: 0000311
Trouble codes:
Coding: 0000017
Subsystems:
Trouble codes:
56 Radio
Coding: 0000001
Trouble codes:
Subsystems:
Trouble codes:
62 Rear Left Door
Coding: 0003114
Trouble codes:
6D Deck Lid Control
Subsystems:
Trouble codes:
72 Rear Right Door
Coding: 0003114
Trouble codes:
Coding: 0200016
Trouble codes:
77 Telephone
Coding: 0010920
Trouble codes:
