mlj76 Posted November 21, 2021 Posted November 21, 2021 Hey people have an 2004 avant, the issue I have is the rear window heater does not work and as it’s getting to that time of year this good become a bit of a pain I push the button and the light comes on but then goes straight off, and with no difference to the rear window I’ve checked the fuses and can’t see any issues there seems to be a few lines on the rear window elements that look a bit worse for wear but when it comes to electrical issues I’m lost am I missing something simple here?
Magnet Posted November 21, 2021 Posted November 21, 2021 Hello Michael, Thanks for being in touch. If you have any sections which look worse for wear - as you say, then you should first check the whole element for continuity. Unfortunately if electrics are not your thing, (and taking it you might not have a meter which you are familiar with ) then you are going to struggle to fault find this system - irrespective of what additional tips you may gain from here. If this were mine, I would be investing in an hour’s time with a trusted auto electrician. He will easily diagnose the cause, and inform you of the anticipated work. One place I can point you to looking at, would be the flexible harness which links from the body to that tailgate. It would be worth carefully pulling back the rubber covering and checking for any broken cables in this section. Very prone to breaking due to flexing as the boot is opened and closed. Kind regards, Gareth. 1
Stevey Y Posted November 21, 2021 Posted November 21, 2021 Hi most likely a corroded connector where the wiring goes on to the fixing on the window the bcm will always turn something off that is raising a current resistance. Steve.
