Hi hope someone can held
Audi sq5 3litre diesel
Broke down last week and had to be recovered burst plastic connector on the diesel flow and return lines and injector 6 faulty and open circuit on bank 1
Injector replaced and new fuel line
But the car is still in limp mode and reading open circuit bank A
Hi try inspecting the wiring loom to that injector especially the plug connector to the injector as these are prone to corrosion, please can you quote the DTC number.
Hi Steve
Fault code P2146
1 hour ago, Mark leonard said:
Hi Steve
Fault code P2146
Hi, according to what I have read the code is for the  injector power supply caused by a fault at the injector plug or the wiring, which begs the question when you replaced the offending injector was it second hand/new and did you recode it to the car.
Hi Steve
it was a new injector for number 6 and this has been recoded I have just done a noid test and have no power to injector 2 or 3 so will have to check for the offending connector/ wire or Fuse/ relay
Can't find the relays except for one in the boot
21 minutes ago, Mark leonard said:
Hi Steve
Hi try a few of the other forums as the Americans are big on posting fuse box/ relay diagrams, I will ask my bud at the garage tomorrow as he does a fair few Audis and might know where to look for the relays, or even come across the problem before.
  • Join The Club
    Join the Audi Owners Club and be part of the Community. LESS ADS & It's FREE!
