Hi all i  retrofit Xenons and auto level controls to my audi A5 2013
since i have done this i have lost my front pdc and front windscreen washer
i have the front pdc displayed on the mmi screen but they just dont show how close i am to things
i have checked continuity on the washer wires and they are fine if i go in to measuring blocks i can see the when i pull the stalk that the signal is being received and i have checked the washer pump on another car and that's fine
i have changed my bcm1 from 8K0 907 063 DC to 8K0 907 063 DH i have also had component protection removed
can anyone help or point me in the right direction to start looking at things
[CODE]Sunday,21,November,2021,17:00:58:23200
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8 x86
VCDS Version: 21.9.0.2
Data version: 20210903 DS330.0
www.Ross-Tech.com
VIN: WAUZZZ8T8DA048715   License Plate: 21-11-2021
Mileage: 181140km-112555mi   Repair Order:
Chassis Type: 8T-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 55 56 5F 62 6C 72
VIN: WAUZZZ8T8DA048715   Mileage: 181140km-112555miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CJCB)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 JP    HW: 03L 906 018 JL
   Component: R4 2,0L EDC   H25 2842
   Revision: 45H25---    CVN: DB1E9282
   Coding: 0A194012232401080000
   Shop #: WSC 40012 002 104857
   ASAM Dataset: EV_ECM20TDI01103L906018JP 003005
   ROD: EV_ECM20TDI01103L906018AC.rod
   VCID: 010E543F9053AA814E-8054
   VINID: 9D196AAAA2242144401081C1141C5DCFE6
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 CG    HW: 8K0 907 379 CG
   Component: ESP8 front    H09 0100
   Revision: --------    Serial number: --------------
   Coding: 161544
   Shop #: WSC 06325 000 00000
   VCID: 0008513B9359A38941-8054
Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
   Part No SW: 8K0 907 064 GB    HW: 8K0 907 064 FB
   Component: BCM2 2.0      H12 0633
   Revision: 00002001
   Coding: 03B44000000000000000
   VCID: 76E437E3C19D9D396B-8022
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Component: FBSAUDIB8 IDG  H71 0083
   Serial number: 0512000083987008
   Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
   Component: J764 ELV MLB  H40 0046
   Serial number: 2312000281568013
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K2 820 043 AH    HW: 8K2 820 043 AH
   Component: KLIMA 3 ZONEN H04 0123
   Revision: D0000000    Serial number: 01131220120005
   Coding: 342402E000
   VCID: 6FEA0287BEC7ACF1A8-803A
Address 09: Cent. Elect. (J519)       Labels:. 8K0-907-063.clb
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Component: BCM1 1.0      H16 0103
   Revision: 08016001    Serial number: 00001101019302
   Coding: 260000118034AFC00081400000001D0D001D020827090201000008000400020000000034000000
   Shop #: WSC 06325 123 12345
   VCID: 78F839DBCB89EB4979-802C
   Subsystem 1 - Part No SW: 8T2 955 119 D    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 141212  H13 0080
   Serial number: SWF12120145338
   Coding: 00FD11
   Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
   Component: G397_RLFS  H06 0002
   Serial number: 20833742
   Coding: 02005D
   Subsystem 3 - Part No SW: 8K0 941 531 AS    HW: 8K0 941 531 AS
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001012124109
   Subsystem 4 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H03 0003
   Serial number: F2780F56000000000001
1 Fault Found:
00156 - Control Circuit for Windshield Washer Pump
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 181
                    Mileage: 181143 km
                    Time Indication: 0
                    Date: 2021.11.21
                    Time: 16:56:16
Address 15: Airbags (J234)       Labels:| 8K0-959-655.clb
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Component: AirbagVW-AU10 H45 0610
   Serial number: 003KFD97B833
   Coding: 30533938363030303030554A305238543053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003010
   ROD: EV_AirbaECUVWAUDI010_003_AU48.rod
   VCID: 4898891BF3E95BC9C9-801C
   Crash sensor for side airbag: driver side:
   Serial number: 6334MSME75754B6BT
   Front Passenger's Side Airbag Crash Sensor:
   Serial number: 6344MSME75432E5CQ
   Rear Side Airbag Crash Sensor (on driver's side):
   Serial number: 6352QSME1A2910505
   Passenger side rear thorax airbag crash sensor:
   Serial number: 6362QSME78273B44O
   Crash sensor for front airbag: driver side:
   Serial number: 63732SME0B28384A2
   Crash sensor for front airbag: front passenger side:
   Serial number: 63832SME07280462T
Address 16: Steering wheel (J527)       Labels:. 8K0-953-568.clb
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20130325001262
   Coding: 000016
   VCID: 4FAAA2071E878CF188-801A
   Component: E221 - MFL  H03 0004
Address 17: Instruments (J285)       Labels:. 8T0-920-xxx-17.clb
   Part No SW: 8T0 920 983 M    HW: 8T0 920 983 M
   Component: KOMBIINSTR.   H35 0556
   Revision: 00000000    Serial number: UUW27RJDD
   Coding: 33AD300002012600010000
   VCID: 4898891BFBE95BC9C9-801C
Address 19: CAN Gateway (J533)       Labels:. 8T0-907-468.clb
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0055
   Revision: 1Y060027    Serial number: 2741Y12C2101F2
   Coding: 80CF07FF00
   VCID: 4A9CB313E5E5A9D9DF-801E
   Subsystem 1 - Part No SW: 8T0 915 181     HW: 8T0 915 181
   Component: J367-BDMHella  H03 8041
   Serial number: 9361038801
   Subsystem 2 - Part No SW: 8K0 959 663     HW: 8K0 959 663
   Component: J532_DCDCStab  H17 0042
   Serial number: 12354000711011200181
Address 42: Door Elect, Driver (J386)       Labels:. 8K0-959-793.clb
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 011502625001450005
   VCID: 56A45763215DFD394B-8002
Address 44: Steering Assist (J500)       Labels:| 8K0-909-144.clb
   Part No SW: 8K0 909 144 F    HW: 8K0 909 144 B
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0011131730
   Coding: 100000000001
   Shop #: WSC 06324 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008014
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3460CDEB9F61CF2995-8060
Address 46: Central Conv. (J393)       Labels:. 8K0-907-064-46.clb
   Revision: 00002001    Serial number: 0300017325
   Coding: 013B062220B900C08320043680000000
   Subsystem 1 - Part No: 8K0 951 177
   Component: DWA-Sensor  H02 0040
   Subsystem 2 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
Address 52: Door Elect, Pass. (J387)       Labels:. 8K0-959-792.clb
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   Coding: 011502225C01450005
   VCID: 55A6506F3C5BF62142-8000
Address 53: Parking Brake (----)       Labels: 8K0-907-801-V2.clb
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 20000000209472
   ASAM Dataset: EV_ParkiBrake 001027
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3878F9DB83092B49B9-806C
Address 55: Headlight Range        Labels: 8K0-907-357.clb
   Part No: 8K5 907 357 B
   Component: Dynamische LWR  H02 0010
   Revision: 00000001    Serial number:
   Coding: 0000001
   VCID: 397EFCDF7003324146-806C
Address 56: Radio (R)       Labels:. 4F0-035-0xx-56.clb
   Part No SW: 4G0 035 056 J    HW: 4G0 035 056
   Component: Radio U STD   H60 0133
   Revision: AB001007    Serial number: 230L40C7578870
   Coding: 010003020100000001
   VCID: 2858299B5BA9BBC929-807C
Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
   Part No SW: 8R2 035 666 L    HW: 8R2 035 666 C
   Component: H-BN-EU       H45 1036
   Revision: --------    Serial number: 206L-0C7511806
   Coding: 130101040006C1EF0180CF5E00000403E40000020000000000
   VCID: 428C9B33DDD5719917-8016
   Subsystem 1 - Part No: 8R0 060 884 HQ
   Component: EUR 2021  3201
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130L/0C2607696
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Component: E0380 Bedient  H02 0030
   Serial number: 00000001365606
   Subsystem 4 - Part No: 8R0 060 961 E
   Component: CD-Database  4949
1 Fault Found:
01043 - Control Module; Incorrect Software Version
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 181
                    Mileage: 181143 km
                    Time Indication: 0
                    Date: 2021.11.21
                    Time: 16:40:03
             Freeze Frame:
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00000010
Address 62: Door, Rear Left (J388)       Labels:. 8K0-959-795.clb
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0304
   Coding: 010402224001450005
   VCID: 59BE5C5F5043D24166-800C
Address 6C: Back-up Cam.        Labels: 8T0-907-441.clb
   Part No SW: 8T0 907 441 C    HW: 4L0 907 441 B
   Component: J772__Rearview      0040
   Revision: --H04---    Serial number: 525PA8-J0392UV
   Coding: 1022006
   VCID: 3878F9DB4B092B49B9-806C
Address 72: Door, Rear Right (J389)       Labels:. 8K0-959-794.clb
   Component: TSG HR        H07 0304
End-------------------------(Elapsed Time: 03:54)--------------------------
[/CODE]
My advice would be to get an auto electrician to take a look. However hate to be a barer of bad news but the UK government has changed the rules regarding vehicle lighting. I believe you a now not allowed to upgrade a car lighting system from what it was when it left the factory. It is/going to be an mot fail.
How would they know it’s all been done to oem spec lights auto level and headlight washers?
Hi, Steve is right as all the new MOT equipment throws up the build specs for lighting etc so the tester knows what he had to check, my local garage I use has an MOT bay next door, when I was down there earlier this week I was chatting to the tester about the pile of H4 Led bulbs on top of the the bench, apparently they are from the many MK5/6 Fiestas he MOTs for the local boy racers he used to be able to give a non urgent advisory about the foggy beam pattern but one year on its now law they have to be fitted with the type of bulb the car left the factory with.
I admire your reasoning but you have done everything bar fitting a range control module for the self levelling system as on Audis with this fitted way before your year have all had this, even my A6 has one as that is HID but has no washers for the lights as it comes fitted with D5S 25w bulbs which use less power than say D3S/D1S which are all 55w therefore under European law washers are not required, as for your other problems its not recognising the new BCM for some reason, when your car reached the end of the production line it is then plugged into a massive mainframe computer which dishes out the correct software version for each module on the build specification, what type of lights used, what fuel used, what engine power output is required, all these modules talk to the ECU which digests the information while in contact with that software version it recognises, no recognition no communication then the ECU starts cancelling functions that it can't recognise from that software, you really should see the size of the Sony can bus I had to have fitted when my cab meter was fitted just to stop the BCM from spitting its dummy out, thats why hardwire dash cams are clever as they piggy back on to an existing fuse or a designated spare fuse station but are never noticed as they draw less than 2amps, the electrical system is designed to ignore really low voltage drains as they don't have the potential to cause real problems within the programmed perameters.
I have fitted range control address 55 on my auto scan. Don’t suppose you have a link or any online info regarding the build spec being check at the mot station as I’m not able to find anything online. Would be good to have a read up on it.
Hi I think this information is exclusive to the stations as it beggars belief the amount of double logins and the swipe card that is used just to get into the system, its getting that tricky now as in the old days with the emissions if you had a car that had failed you could always use a car that had passed and use that reading but now because the Vin has to be entered it knows what it should be checking so if any other vehicle is used it clocks up a fail if there is any descrepency, they are electronically heading at type approval even though its a European thing and we are not in it anymore, I think your main problem is the non compatible software programmed into the new BCM, also I would be checking if that year and model were ever produced with HIDs if yes then you are in with a shout as you could always tell them it was a grey import as normally information on those is pretty rare, as for the software I would not know where to begin as thats a bit above my pay grade, as for the MOT info I am only going on what I have been told by a couple of testers, I have two MOTs a year as my car is used as a cab, I had fitted higher output bulbs before the last one and the tester spent ages looking at the headlights and then commented they seemed brighter in the beam reader so I just told him I had replaced the bulbs so he pulled a face and let it go.
Hi just a thought have you tried coding the new BCM with the old units coding, save both so you can always go back.
All coding was saved and double checked between both modules I used turns out there’s a fault in the DH module as the old module was put back in everything worked brought another DH module and everything works with that one so It could only be a faulty module just need to get component protection removed again.
Hi Glen I did a bit of digging today and phoned the most sensible tester I know, it appears Steve and myself were a bit adrift on this one, he must have read the same legislation I did last year which has changed again this year, the guy sent me a bulletin he had received this year, apparently according to him the legislation is aimed at people who bore holes in their halogen head lights and then fit retro fish eye lenses and Hid units or the same with LED bulb conversions as he explained if your car is fitted with O.E. Specific headlight units and all the relevant equipment to operate them he couldn't see a problem with that as it may well have come as an option, what the tester is looking for is a nice sharp beam cut off with no vague cut off lines and the o/s unit cut off being slightly under the n/s. I owe you a big fat apology as you have done everything in the correct order and I was wrong.
Yer I did see that yesterday when I looked but thought I had miss read it. Thanks for the info 👍🏻
Now I've learnt something new 🙂
If you think we were confused that won't even come close to what the testers are dealing with, my chap is constantly dealing with the latest changes they keep introducing and then change their mind a while later, example all cars emissions should meet the figure on the production sticker on the drivers door rocker panel, so if it did not have a sticker you had to fail the car, then they sent out a directive if it has not got the sticker as long as the levels don't exceed the max permissible on the VOSA chart the car passes even if it might have had a lower figure on the now absent sticker.
Hmm, now how is that fair. I'd be tempted to remove the stickers on my two old cars including my a6 out if principal.
