Dan W Posted November 26, 2021 Posted November 26, 2021 Hi, my engine Audi S3 2008's engine is cooked due to an oil pressure issue. I wondered if anyone can recommend and garage near Surrey in the UK who can look at the supply and fitting of a new engine? Any suggestions would be welcome! Thanks
Stevey Y Posted November 26, 2021 Posted November 26, 2021 4 hours ago, Dan W said: Hi, my engine Audi S3 2008's engine is cooked due to an oil pressure issue. I wondered if anyone can recommend and garage near Surrey in the UK who can look at the supply and fitting of a new engine? Any suggestions would be welcome! Thanks Hi, its not that close but I can recommend Regal Engines in Purfleet Essex, a lot of my cabbie mates have used them and they are very good, might be worth giving them a ring as they are very friendly and don't mind handing out advice. Steve.
Dan W Posted November 29, 2021 Author Posted November 29, 2021 Thanks Steve much appreciated. Funnily enough I have received a quote from Regal Automotives Ltd who are also based in Essex. Do you know if that's the same garage? Or have you heard of them? Thanks Dan
Stevey Y Posted November 30, 2021 Posted November 30, 2021 21 hours ago, Dan W said: Thanks Steve much appreciated. Funnily enough I have received a quote from Regal Automotives Ltd who are also based in Essex. Do you know if that's the same garage? Or have you heard of them? Thanks Dan Hi its quite a big husband and wife concern with branches all over London so its perfectly possible, head office I believe is in Thurrock. Steve.
