Gerd Posted December 2, 2021 Share Posted December 2, 2021 Hi all. It’s a 2010 A6 Le Mans Avant 2.0lDiesel. Has the led daytime running lights as part of the headlamp cluster. Driver’s side main beam not working. Bought a new bulb, it’s the one with the integrated block(ballast?) no fix. swapped sides, looks likely my bulbs are ok so suspecting the fuse… but where to find it? The owners manual tells me headlight fuses are under the covers at the ends of the dash near the door hinges… but although the space is there, the designated fuse slot is blank, both sides. No luck in the luggage compartment fusebox either. Please…Any idea where I should start looking? Thanks GerD Quote Link to comment Share on other sites More sharing options...
Steve Q Posted December 5, 2021 Share Posted December 5, 2021 Found this link. Which might help: https://imgvehicle.com/audi/a6-c6/fuse-box Quote Link to comment Share on other sites More sharing options...
Gerd Posted December 10, 2021 Author Share Posted December 10, 2021 Thanks for sending this over Steve. Unfortunately I’m no further along. I’d previously located all 3 fusebox locations in the vehicle. Problem is..the fuse location for headlights shown on both the cover plate and the owners manual is a blank space. My model is the le mans avant 2010. It’s almost like the cover plate and the manual refer to a different model… does anyone know if there was a re-jig of the electrical distribution around that time/variant? cheers. Ger. Quote Link to comment Share on other sites More sharing options...
Steve Q Posted December 10, 2021 Share Posted December 10, 2021 Sorry it's not helped. I've do e further research but can't find anything. This might be a case that'll have to speak to Audi. Quote Link to comment Share on other sites More sharing options...
Gerd Posted December 10, 2021 Author Share Posted December 10, 2021 Cheers Steve, I very much appreciate your willingness to help. Ger Quote Link to comment Share on other sites More sharing options...
Steve Q Posted December 10, 2021 Share Posted December 10, 2021 1 hour ago, Gerd said: Cheers Steve, I very much appreciate your willingness to help. Ger You're welcome. They're really is a shortage of info online. Quote Link to comment Share on other sites More sharing options...
Turr Posted May 30, 2022 Share Posted May 30, 2022 Did you find the issue, i have the same problem on the left side of mine and blank on fuse 18... Quote Link to comment Share on other sites More sharing options...
RoyC Posted May 31, 2022 Share Posted May 31, 2022 On 12/10/2021 at 2:22 PM, Steve Q said: Sorry it's not helped. I've do e further research but can't find anything. This might be a case that'll have to speak to Audi. Put a new ground wire from that head light. A lot of problems can be traced back to poor grounds. Quote Link to comment Share on other sites More sharing options...
