benisa Posted December 5, 2021 Share Posted December 5, 2021 Hello i have a audi TT MK 2 2013 and the blower has stopped working i have looked at the fuses under the bonnet + the ones in the side panel all seem ok believe it a 40 amp that does the blower the air con does not work light comes on but then it I think needs to blower to work it i would have to take the glove compartment out to get at the IT if its the blower motor/correct/ is it a big job if its the blower any help would be great THANKS ! Quote Link to comment Share on other sites More sharing options...
Steve Q Posted December 5, 2021 Share Posted December 5, 2021 Is it worth checking the relays? Also you could try a diagnostic check to see if any fault codes flag up regarding the system. But you're most likely right it being the blower motor. But it could also be the control unit (buttons). Quote Link to comment Share on other sites More sharing options...
benisa Posted December 6, 2021 Author Share Posted December 6, 2021 thanks will have a check looking on good old YOU TUBE most things lead to the fan or resistor so will pull it out and see if suspect will just change both thanks again Quote Link to comment Share on other sites More sharing options...
Steve Q Posted December 7, 2021 Share Posted December 7, 2021 No probs at all Quote Link to comment Share on other sites More sharing options...
