pdmgough Posted December 7, 2021 Posted December 7, 2021 (edited) Hello I have an odd issue. I changed the oil and filter on my A1 1.4 TFSI and there was an oil pressure warning. I checked and inside the housing on the engine where the oil filter screws into is a rubber sleeve or gasket. Seems the top of this, where it has a lip or shoulder that sits on the top and meets up with the rubber seal on the filter has a small split in it and leaks when under engine pressure. It is removable quite easily. I went to Audi and apparently it does not exist, so am unable to find a replacement. Has anyone had experience with this as I cannot drive the car as it gives low oil pressure warning and tells me to turn engine off. Regards Paul Edited December 7, 2021 by pdmgough
Stevey Y Posted December 7, 2021 Posted December 7, 2021 2 hours ago, pdmgough said: Hello I have an odd issue. I changed the oil and filter on my A1 1.4 TFSI and there was an oil pressure warning. I checked and inside the housing on the engine where the oil filter screws into is a rubber sleeve or gasket. Seems the top of this, where it has a lip or shoulder that sits on the top and meets up with the rubber seal on the filter has a small split in it and leaks when under engine pressure. It is removable quite easily. I went to Audi and apparently it does not exist, so am unable to find a replacement. Has anyone had experience with this as I cannot drive the car as it gives low oil pressure warning and tells me to turn engine off. Regards Paul Hi sorry you will have to buy a new filter as the sealing ring comes with the filter, or are we talking of a split in the metal housing in which case they are bolted to the engine and are replaceable even if its a second hand unit, it will help a lot if you can pst a picture of the offending split. Steve.
pdmgough Posted December 7, 2021 Author Posted December 7, 2021 I will take a picture tonight and post it
