Chrisrt Posted December 13, 2021 Share Posted December 13, 2021 Hey all, I'm having a wierd problem with my coolant header tank, I've recently had the radiator replaced as it developed a leak, but since having the new radiator fitted now, it reaches 90 and doesn't shown any signs of over heating but when checking the header tank my level goes to minimum when it was showing in-between min and max, if left to cool down and open the header tank it releases air and the coolant goes back to the level in between min and max, any help would be appreciated Quote Link to comment Share on other sites More sharing options...
Stevey Y Posted December 13, 2021 Share Posted December 13, 2021 4 minutes ago, Chrisrt said: Hey all, I'm having a wierd problem with my coolant header tank, I've recently had the radiator replaced as it developed a leak, but since having the new radiator fitted now, it reaches 90 and doesn't shown any signs of over heating but when checking the header tank my level goes to minimum when it was showing in-between min and max, if left to cool down and open the header tank it releases air and the coolant goes back to the level in between min and max, any help would be appreciated Hi if you recently had the rad changed its probably the last of the air escaping when you remove the cap, if its not overheating don't worry as if you top it up to between min-max when warm it should stay there except when very hot and it will register max because that is why its correct term is expansion tank. Steve. 1 Quote Link to comment Share on other sites More sharing options...
