hi im new to the forum ,i have just bought an 2013 a3 sportsback ,
but i bought it with a handbrake problem ,i have replaced one rear caliper and motor
but i still have a fault with the h/brake module which i have been told by a friend to replace
the module ,but can anyone help with the location of the module ?
many thanks and hope someone can help
paul
hi thank you for your help
when i open the boot of my car
and i open the panel up ,i can only see the car jack etc small storage area
have i to remove the panel nearest the rear seats on the right handside ?
hope you can help
cheers paul
hi thank you very much
i will sort it tomorrow when i get back to my garage
hopefully it will work
once again thank you ,i will let you know how i got on
i phoned my local audi dealer today and spent an hour
on the phone with him ,he cannot find the module
he asked myself did it have a module ?/
i cant see the electronic handbrake working without a module ?
he told me he would ring me back but he did not
so il wait until tomorrow and hopefully il have the module out of my car
and will be able to give him the module number to order a new one
hopefully
cheers paul
No probs at all. Once you find it, my advice would be to source a used one first. As it'll be cheaper and be less money lost if it transpires it's not the module.
Also I'd recommend a diagnostic check.
hi steve ,i checked in the rear of the car and there is no module
or fuse box in the rear ,i asked a friend who would work on these
and he thinks it is below the central console of the car ?
have you heard of this before steve ?
il remove the console in the morning ,but it is strange my local
audi dealer cannot find the module ,i need to get the number of it
even to buy a second hand one as the dealer has been no  help
any more help would be great steve
cheers paul
Hi I would be getting the car scanned for faults, you say that you replaced a calliper but no mention of if you re programmed the new calliper as they are not plug in and play thats why they tell you not to unplug your original calliper as it loses its values.
hi steve the caliper was reset using vcds,the motor on the old one was just winding and not doing
anything ,a new caliper with motor sorted that out ,but i am getting the fault code on vcds telling me
incorrect data from handbrake module ,the module is hardly incorporated in the abs module as that link maybe suggests ?
paul
I'm not sure what else to advise as I've struggled to find the information too. My advice would be to contact sone local independent Audi specialists
