When I first start to play music the front door speakers sound rough. After a few minutes it sounds okay. If I park and want to play the music at low volume, it again sounds rough, lots of bass distortion. As soon as I pump it up and drive it sounds okay again. Any ideas? This is an 03 A6 C5.
I'd be speaking to an auto electrician about this as it could be a wiring issue. As your car has Bose then the sub should be in the passenger side boot panel I think.
The first thing I'd do if you're mechanically minded is take off the door cards and inspect the wiring.
Also this link might help:
https://www.vwaudiforum.co.uk/forum/showthread.php/111890-A6-2-5-TDI-SE-power-crackle-through-stereo-on-start-up
