Hi All
I am a new member here so firstly thanks for the support.
I have a 2.0 TDi Auto Quattro Black Edition (2017). I love my car and have had it for over 3 years now. A few days ago I got a flashing coil light on the dashboard during part of a half hour journey. This did not come back on since then in the 2-3 other journeys I have done. I did manage to get the fault codes which are below
2 Faults Found:
5290 - Throttle Actuator Control Circuit
          P2100 00 [100] - Open Circuit
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 7
                    Mileage: 54579 km
                    Date: 2021.12.23
                    Time: 18:03:40
                    Engine RPM: 956.00 /min
                    Normed load value: 20.4 %
                    Vehicle speed: 11 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 55 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 14.400 V
                    Unlearning counter according OBD: 40
                    Mass airflow sensor 1 bank 1 airflow: raw value: 516.6 mg/stroke
                    Throttl.valve adapt. 1 bank 1: posit feedback - Specified value: 0.00 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Actual value: 0.00 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Offset closed: -0.09 %
                    Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7: 0
                    Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7: 9
                    Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7: 55
                    Throttl.valve adapt. 1 bank 1: posit feedback - Raw voltage: 4496.4 mV
5296 - Throttle Valve Actuator Module (J338): Motor Circuit
          P2102 00 [032] - Signal Low
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 54576 km
                    Date: 2021.12.23
                    Time: 18:00:50
                    Engine RPM: 1477.50 /min
                    Normed load value: 92.2 %
                    Vehicle speed: 96 km/h
                    Coolant temperature: 90 °C
                    Intake air temperature: 87 °C
                    Voltage terminal 30: 14.420 V
                    Unlearning counter according OBD: 39
                    Mass airflow sensor 1 bank 1 airflow: raw value: 731.2 mg/stroke
                    Throttle valve adapter 1 bank 1: monitoring - status-Bits 0-7: 8
There was also a little smell of what I think is diesel when driving, but only on the journey after this happened.
Any thoughts?
Thanks!
