Hi all,
I have owned my much loved 2012 Q7 for only a few months and have noticed that the passenger side headlight has a lot of condensation on the inside and an accumulation of water at the very bottom. The drivers side is totally clear so I know its not just normal warm air touching cold surface type condensation. Is there an easy fix for this. Any help would be appreciated.
It might be worth you removing the headlight and try and dry it out. Removing it will allow you to fully inspect it for cracks or perished seals etc
Cheers and thanks for the response. I guess that was my next plan of action to try to resolve it.
It might be something as simple as the bulb holder cover not being secured correctly.
Good shout. I’ll check that as well. Cheers Steve.
