MikeFlynny Posted January 1, 2022 Posted January 1, 2022 I have a fault with nearside headlamp assembly.initially headlight stopped working so replaced bulb. Then indicator bulb developed intermittent fault, now no lights at all work in unit. My ideas?. Tried an OBD however no faults are showing up. Thanks
Stevey Y Posted January 1, 2022 Posted January 1, 2022 1 hour ago, MikeFlynny said: I have a fault with nearside headlamp assembly.initially headlight stopped working so replaced bulb. Then indicator bulb developed intermittent fault, now no lights at all work in unit. My ideas?. Tried an OBD however no faults are showing up. Thanks Hi probably corrosion in the pinned loom plug that connects with the headlight unit.
