103BHP Posted January 4, 2022 Posted January 4, 2022 Hi all need advise I have a flashing coil warning light the car is running well but I have replaced the MAF sensor just in case. This is the thing when I clear the fault code the starter motor does not engage the first time I turn the key when I try it a second time the warning light comes back and it starts no problem. Also start stop has stopped working i hope someones come across this before apart from this light the car runs well, I would appreciate any advise thanks
Stevey Y Posted January 4, 2022 Posted January 4, 2022 6 minutes ago, 103BHP said: Hi all need advise I have a flashing coil warning light the car is running well but I have replaced the MAF sensor just in case. This is the thing when I clear the fault code the starter motor does not engage the first time I turn the key when I try it a second time the warning light comes back and it starts no problem. Also start stop has stopped working i hope someones come across this before apart from this light the car runs well, I would appreciate any advise thanks Hi probably a knackered battery. Steve.
103BHP Posted January 4, 2022 Author Posted January 4, 2022 Sorry steve forgot to mention the battery is 4 months old bought and matched to the car from halfords
Steve Q Posted January 5, 2022 Posted January 5, 2022 Sounds like you've done a great amount of diagnostics and work. If the diagnostic check says a starter motor then that would be my next port of call.
103BHP Posted January 5, 2022 Author Posted January 5, 2022 (edited) Thanks Steve I've got a mobile diagnostic mechanic coming tomorrow for s definitive answer and will post to he findings Edited January 5, 2022 by 103BHP
