Keith1505 Posted January 6, 2022 Share Posted January 6, 2022 Hi again! Second post in as many minutes, but I've only just found this site and am keen to get help with a second niggle. The previous owner has swapped the passenger headrest with one from the back. Not a problem, I'll just swap them back... or so I thought! The front one comes out easily, but the original passenger headrest won't come out of the rear seat, I've taken the clip apart at the base of the headrest to see if that helps but it doesn't, the headrest seems jammed in... any ideas? Thanks in advance. Keith Quote Link to comment Share on other sites More sharing options...
cliffcoggin Posted January 6, 2022 Share Posted January 6, 2022 I suspect it is simply jammed from being slightly twisted. If wriggling alternate sides does not work I can only suggest brute force, Quote Link to comment Share on other sites More sharing options...
Keith1505 Posted January 6, 2022 Author Share Posted January 6, 2022 Thanks for that mate, I'll give it a go and see if that helps 👍 Quote Link to comment Share on other sites More sharing options...
