Hi all,
I can hear a bearing sound from my steering wheel when at slow speeds or a complete stop. It is audible outside the car but specifically inside, and it sounds like a belt driven simulator wheel when turned. What am I looking at?
Thanks.
I don't recognise your description "belt driven simulator wheel", but a noise when turning the steering wheel could be one of the bushes supporting the column or one of the rubber bushes in the steering linkage.
I haven't the faintest idea. The cost will depend on which bush needs to be changed and whether you are going to do the job yourself or pay somebody to do it for you. The first task surely is to identify what precisely is wrong before making a decision on a solution.
I suggest you get somebody to wriggle the steering wheel to and fro while you look and feel the bushes holding the steering column (I think there are two of them), then do the same to the steering linkage under the car including the rack mounting points. If the sound does not give away the location the vibration of a creaky joint sometimes will.
