Hi,
I have an obd scanner that works via Bluetooth to make some coding changes to my car but can find an app that’s really compatible with the car. (2014) I’ve tried Carly and car scanner and others. Any suggestions?
It seems I need the obdeleven adapter to use that app or mine isn’t compatible. I’ll keep looking.
Expand
No, you just buy the OBDEleven device and you're away. Connects to your phone and you can do adaptations, long-coding (if you are brave) and of course scan for faults, and clear them.
Or get VCDS off eBay for £175
  On 1/12/2022 at 12:27 PM, Entwood said:
This seems exceedingly cheap .... am I right to be highly suspicious ??
 VCDS Diagnostic interface for VW AUDI SKODA SEAT FULL VERSION | eBay
My allroad is 2014 version so this "should" work ... but .........
Expand
If it comes with the full VCDS software, that's a !Removed! bargain. I may beat you to it 🙂 You can always return it if it doesn't work.
Put in a saved search in eBay and you'll get emails when new ones appear. That one did seem good. I nearly got one just before xmas - as I say £175.
