Simon2168 Posted January 11, 2022 Posted January 11, 2022 Hi I'm new to this but here goes.... My a6 estate 2007 sometimes when i try to start it it turns over but makes a horrible like clatter noise and shudders a bit then then starts like nothing happened, sometimes if it goes on a little longer the oil pressure logo comes up on the dash so i turn it off and try again and its fine. It happens probably once a month and thats it! I was wondering if it could be something to do with the fuel pump?? Cheers for any help or advice 😃 Simon
Simon2168 Posted January 12, 2022 Author Posted January 12, 2022 Sorry did you mean fault codes? No none at all
Simon2168 Posted February 15, 2022 Author Posted February 15, 2022 Hi all it turned out to be the alternator pulley, i didn't realise that when you change the tensioner and fan belt you should always change the pulley as well! But all sorted and drives and starts like a dream 👍
Steve Q Posted February 15, 2022 Posted February 15, 2022 1 hour ago, Simon2168 said: Hi all it turned out to be the alternator pulley, i didn't realise that when you change the tensioner and fan belt you should always change the pulley as well! But all sorted and drives and starts like a dream 👍 Glad you got sorted ☺️ 1
Stevey Y Posted February 15, 2022 Posted February 15, 2022 8 hours ago, Simon2168 said: Hi all it turned out to be the alternator pulley, i didn't realise that when you change the tensioner and fan belt you should always change the pulley as well! But all sorted and drives and starts like a dream 👍 Hi a deep sigh of relief well done. 1
