Hi I'm new to this but here goes.... My a6 estate 2007 sometimes when i try to start it it turns over but makes a horrible like clatter noise and shudders a bit then then starts like nothing happened, sometimes if it goes on a little longer the oil pressure logo comes up on the dash so i turn it off and try again and its fine. It happens probably once a month and thats it! I was wondering if it could be something to do with the fuel pump?? Cheers for any help or advice 馃槂 Simon
Hi all it turned out to be the alternator pulley, i didn't realise that when you change the tensioner and fan belt you should always change the pulley as well! But all sorted and drives and starts like a dream 馃憤
Expand
Glad you got sorted 鈽猴笍
  • Thanks 1
Expand
Hi a deep sigh of relief well done.
  • Thanks 1
