Jabberwock Posted January 12, 2022 Posted January 12, 2022 I have just changed the oil in my 2016 A6 but didn’t check I had a socket large enough for the filter housing before I drained it. So I’ve had to fill the engine with fresh oil with the old filter still in situ for the time being. Once I get a VAG filter tool, can I replace filter without having to redrain the block?
Magnet Posted January 12, 2022 Posted January 12, 2022 Hello David, Yes you can. Worth investing in a premium brand filter if not using a genuine VAG one. Kind regards, Gareth.
Jabberwock Posted January 12, 2022 Author Posted January 12, 2022 Hi Gareth, That’s great. Saves me losing a load of oil and faffing under the car again. Thanks for taking the time to help. Kind regards, David 1
ThomasG Posted January 12, 2022 Posted January 12, 2022 I use an oil pump. Best thing ever. No under the car messing about. 1 1
Stevey Y Posted January 12, 2022 Posted January 12, 2022 On 1/12/2022 at 3:41 PM, Jabberwock said: Hi Gareth, That’s great. Saves me losing a load of oil and faffing under the car again. Thanks for taking the time to help. Kind regards, David Expand Hi I use the appropriate size socket on a 1/2 drive long extension which gives you loads of swing above the engine, the socket size is stamped on the top of the filter housing. Steve.
Jabberwock Posted January 12, 2022 Author Posted January 12, 2022 On 1/12/2022 at 4:43 PM, Stevey Y said: Hi I use the appropriate size socket on a 1/2 drive long extension which gives you loads of swing above the engine, the socket size is stamped on the top of the filter housing. Steve. Expand Thanks Steve, yes I should have looked before clambering under the car. Largest socket I have is 27mm and I just presumed I’d have one big enough...til I tried 🙄
Jabberwock Posted January 12, 2022 Author Posted January 12, 2022 On 1/12/2022 at 4:41 PM, ThomasG said: I use an oil pump. Best thing ever. No under the car messing about. Expand Thanks. I may have a look myself
ThomasG Posted January 12, 2022 Posted January 12, 2022 Also, there's a torque setting for the oil filter too.
Stevey Y Posted January 12, 2022 Posted January 12, 2022 On 1/12/2022 at 5:27 PM, Jabberwock said: Thanks. I may have a look myself Expand Hi I got a Sealey oil extraction pump off eBay about £26.00 had it about three years and its great as is ally do is push the drain side pipe down the dipstick hole until it bottoms out connect to the jump start posts in the engine bay put the bigger hose into a old oil can and fire it up, then carefully picking your tea up observe as the container fills you can see from the markers on the old can how much has come out, 4.7 litres normally, two major rules, get the engine nice and hot, then allow 10 mins for drain back before pumping out. Steve.
ThomasG Posted January 12, 2022 Posted January 12, 2022 And remember the oil in the filter will come out too!! 1
Jabberwock Posted January 13, 2022 Author Posted January 13, 2022 On 1/12/2022 at 8:30 PM, ThomasG said: And remember the oil in the filter will come out too!! Expand Aye, I’ll have sheets and rags at the ready.
Jabberwock Posted January 13, 2022 Author Posted January 13, 2022 On 1/12/2022 at 6:37 PM, Stevey Y said: Hi I got a Sealey oil extraction pump off eBay about £26.00 had it about three years and its great as is ally do is push the drain side pipe down the dipstick hole until it bottoms out connect to the jump start posts in the engine bay put the bigger hose into a old oil can and fire it up, then carefully picking your tea up observe as the container fills you can see from the markers on the old can how much has come out, 4.7 litres normally, two major rules, get the engine nice and hot, then allow 10 mins for drain back before pumping out. Steve. Expand Cheaper than I thought. Thanks for the info, and enjoy your cuppa next time you change your oil 1
