Kev555 Posted May 31, 2022 Author Posted May 31, 2022 Ok 3 months on and car has been off the road a month now as new car has finally arrived for the wife. So busy with life/work so I'm only getting back to it now, I sorted the last fault which was down to the plug issue at the box but the gearbox fault light still comes on when reversing up a steep incline or putting pressure on in reverse. The message goes away after a restart and it behaves normally except the box seems a bit grabby in first gear. No transmission fault codes showing up on the WOW software either? I did do a full box service to rule out that end of things so thinking It has to be the mechatronic thats either worn out or possibly a mechatronic repair kit would cure it? Any advice on how to proceed or any auto box specialists can point me in the right direction or am I looking at a new or reconditioned mechatronic? Ive looked at ecutesting.com who are recommended for repairing these as another option?
Stevey Y Posted May 31, 2022 Posted May 31, 2022 7 hours ago, Kev555 said: Ok 3 months on and car has been off the road a month now as new car has finally arrived for the wife. So busy with life/work so I'm only getting back to it now, I sorted the last fault which was down to the plug issue at the box but the gearbox fault light still comes on when reversing up a steep incline or putting pressure on in reverse. The message goes away after a restart and it behaves normally except the box seems a bit grabby in first gear. No transmission fault codes showing up on the WOW software either? I did do a full box service to rule out that end of things so thinking It has to be the mechatronic thats either worn out or possibly a mechatronic repair kit would cure it? Any advice on how to proceed or any auto box specialists can point me in the right direction or am I looking at a new or reconditioned mechatronic? Ive looked at ecutesting.com who are recommended for repairing these as another option? Hi there are lots of companies that repair these, ECU Testing are about the best if they can't fix it its genuinely had it and they are always capable of offering an alternative solution. Steve.
Kev555 Posted May 31, 2022 Author Posted May 31, 2022 Thanks Steve I was contemplating buying a repair kit myself ATM. I was looking at a good online DIY guide Its a bit tricky in places but looks doable. I will think over it tomorrow after I remove it but looking like ecutesting.com are the better bet as they are quoting £400 for a rebuild on the website if its not scrap plus whatever extra seals I need. Hoping the way mine is behaving on the modest side of the stories about faults in these that it is still salvageable.
Stevey Y Posted May 31, 2022 Posted May 31, 2022 2 minutes ago, Kev555 said: Thanks Steve I was contemplating buying a repair kit myself ATM. I was looking at a good online DIY guide Its a bit tricky in places but looks doable. I will think over it tomorrow after I remove it but looking like ecutesting.com are the better bet as they are quoting £400 for a rebuild on the website if its not scrap. Hi Kev if you think about it logically, ECU Testing is the better bet, worse case scenario is it is scrap for which they only charge a small fee, if its repairable !Removed! marvellous as this comes with a guarantee which you can beat them with if it fails in short order, if you DIY the job and it still won't work you will never know why because us mere mortals don't possess the test rigs they have. Steve.
Kev555 Posted May 31, 2022 Author Posted May 31, 2022 your spot on Stevey, ecutesting.com it is as ive no logical way of testing its good before blowing the price of a repair kit in it. 1
Kev555 Posted June 19, 2022 Author Posted June 19, 2022 I sent the Mechatronic to ECUtesting.com last week on Stevey's recommendation. They contacted me to say they couldn't find any faults in it so I told them to to rebuild it anyways to rule it out as there seemed to be a lack of power in rev which in turn threw up the gearbox malfunction message. Car is now noticeably better in reverse and so far hasn't thrown code back up doing the same manoeuvre which trigged the gearbox malfunction message. Thanks again Stevey. 1
Stevey Y Posted June 20, 2022 Posted June 20, 2022 21 hours ago, Kev555 said: I sent the Mechatronic to ECUtesting.com last week on Stevey's recommendation. They contacted me to say they couldn't find any faults in it so I told them to to rebuild it anyways to rule it out as there seemed to be a lack of power in rev which in turn threw up the gearbox malfunction message. Car is now noticeably better in reverse and so far hasn't thrown code back up doing the same manoeuvre which trigged the gearbox malfunction message. Thanks again Stevey. Keep going Kev, like I said you seem very capable, I am chuffed for you. Steve.
Kev555 Posted June 22, 2022 Author Posted June 22, 2022 Thanks Stevey, its been a long struggle with this one and its not over yet🙄
Stevey Y Posted June 22, 2022 Posted June 22, 2022 12 hours ago, Kev555 said: Thanks Stevey, its big a long struggle with this one and its not over yet🙄 Hi you will beat it I am sure, its like us as we age bits go wrong, and like most of us it can either be cured or controlled. Steve.
Kev555 Posted June 24, 2022 Author Posted June 24, 2022 Lol your right there Stevey, only car seems to be easier sorted and less stubborn😄 1
Kev555 Posted September 17, 2022 Author Posted September 17, 2022 Ok been a while since I was here to update. The car seems to be cured but I haven't been extensively driving it to fully confirm as i had it at a diagnostic specialist for the smoking problem and it was in his yard for over a month. I had issues with that plug at the transmission not connecting properly but got it sorted although down the line it will need a replacement plug on the cars loom. the transmission runs smoothly now with no grabbing or fault codes arising thankfully. Looks like it was worth the price of the repair kit in the Mechatronic.
Steve Q Posted September 18, 2022 Posted September 18, 2022 11 hours ago, Kev555 said: Ok been a while since I was here to update. The car seems to be cured but I haven't been extensively driving it to fully confirm as i had it at a diagnostic specialist for the smoking problem and it was in his yard for over a month. I had issues with that plug at the transmission not connecting properly but got it sorted although down the line it will need a replacement plug on the cars loom. the transmission runs smoothly now with no grabbing or fault codes arising thankfully. Looks like it was worth the price of the repair kit in the Mechatronic. Glad you've got sorted 🙂 let's hope you have no further issues 🙂 1
