Posted (edited)
Hi everyone.
Need some help.
recently i had AD-BLUE delete and stage 1 remap done which was few days ago as had issues with ad-blue sensor and tank so A4audi in glasgow recommended the ad-blue delete and remap.
Everything was fine till past two days i got the Dpf filter light and limp mode isssues.
I have scanned via my rosstech hex-v2 cable and get the following errors.
VIN:    License Plate: OW16
Mileage: 70244km-43647mi   Repair Order:
Chassis Type: F4-AU49 (4M1)
Scan: 01 03 08 09 15 16 17 19 29 2B 39 42 44 46 47 52 5F 82 A5 AC
          BB BC D6 D7
VIN:    Mileage: 70244km-43647miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
29-Left Light -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
39-Right Light -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
82-Head Up Display -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
AC-Reductant Control -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DETA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 AC    HW: 04L 907 309 L
   Component: R4 2.0l TDI   H34 3395
   Revision: B1H34---    CVN: 8830F3874F8B6DFB31AEE350
   Coding: 0A194032232405083408
   Shop #: WSC 65535 000 00000
   ASAM Dataset: EV_ECM20TDI01104L906026AC 004004
   ROD: EV_ECM20TDI01104L906026AC_004.rod
   VCID: 6B823BC283066F13623-803E
   VINID: 9D196AAAA58409844004404214CC410309
2 Faults Found:
31254 - Particle Filter
          P2463 00 [175] - Excessive Soot Accumulation
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 70178 km
                    Date: 2022.02.19
                    Time: 21:31:13
                    Engine RPM: 3232.50 /min
                    Normed load value: 55.7 %
                    Vehicle speed: 88 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 81 °C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 12.760 V
                    Unlearning counter according OBD: 40
                    Counter for regeneration time of particulate filter: 23095.7 s
                    Particle filter: kilometers since last regeneration: 348.3 km
                    Particle filter: soot mass measured: 6.49 g
                    Particle filter: soot mass calculated: 40.00 g
                    Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 0 hPa
                    Particle filter field regeneration: cancel conditions-Bits 0-7: 0
31255 - Diesel Particulate Filter
          P2458 00 [175] - Regeneration Duration
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 70125 km
                    Date: 2022.02.19
                    Time: 20:40:56
                    Engine RPM: 860.00 /min
                    Normed load value: 22.4 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 76 °C
                    Intake air temperature: 38 °C
                    Voltage terminal 30: 14.940 V
                    Counter for regeneration time of particulate filter: 20448.6 s
                    Particle filter: kilometers since last regeneration: 295.5 km
                    Particle filter: soot mass measured: 5.13 g
                    Particle filter: soot mass calculated: 37.76 g
                    Particle filter field regeneration: cancel conditions-Bits 0-7: 99
Readiness: 1 2 0 0 1
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PLU-V1.clb
   Part No SW: 8W0 907 379 E    HW: 8W0 907 379 J
   Component: ESP9 Plus     H06 0593
   CVN: B0FDBA67
   Coding: 0CAA489908A30A9A159F489300825292E6C19630121050A812004A49678369
   Shop #: WSC 06324 790 00001
   ASAM Dataset: EV_ESP9BOSCHAU49X 012014
   ROD: EV_ESP9BOSCHAU49X_012.rod
   VCID: 47CAA772FF2E6B7326B-8012
No fault code found.
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 F    HW: 8W0 820 043 F
   Component: Klima Zone 3  H32 0071
   Coding: 141800295544450D02000100880000000000000000000000000000000000
   Shop #: WSC 06325 790 00001
   ASAM Dataset: EV_AirCondiBHTCAU491 001013
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 3634DAB688C4E2FB4DD-8062
   Fresh air blower control module (front):
   Subsystem 1 - Part No SW: 4M2 820 021     HW: 4M2 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000000887516
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 A    HW: 4H0 907 658 A
   Component: AQ_Hum_Sensor  H01 0003
   Serial number: 7F68CC28000000000001
   Rear A/C control head:
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: E265 Kli Fond  H40 0080
Address 09: Cent. Elect. (J519)       Labels:* Redir Fail!
   Part No SW: 8W0 907 063 BF    HW: 8W0 907 063 BF
   Component: BCM1 MLBevo   H13 0248
   Coding: 07501143E11800CD014487151B0C00B9110B3108000000000000000020001A810A450122025601
   ASAM Dataset: EV_BCM1BOSCHAU736 016006
   ROD: EV_BCM1BOSCHAU736_016.rod
   VCID: 00587C6E9A809C4BA71-8054
   Wiper motor control module:
   Subsystem 1 - Part No SW: 8W2 955 119     HW: 8V2 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS491 160312  043 0813
   Serial number: 894253?0301607202303
   Coding: 5BC7F7
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 81A 955 555     HW: 81A 955 555
   Component: G397_RLFSS  H06 0001
   Serial number: 20018931X81A95555500
   Coding: 02005D
   Light switch:
   Subsystem 3 - Part No SW: 4M0 941 531 AB    HW: 4M0 941 531 AB
   Component: E1 - LDS  H06 0008
   Serial number: 04 03 2016  00274925
   Automatic dimming interior mirror:
   Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
   Component: Y7_Innenspieg  H09 0002
   Serial number: GX1CE107041611520368
   Coding: 230000
   Interior Light Module:
   Subsystem 5 - Part No SW: 8W0 947 135 D    HW: 8W0 947 135
   Component: J528-Dachele  H13 0082
   Serial number: B10152417
   Control head for driving and comfort functions:
   Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H16 0010
   Serial number: 2616000026036001
   Coding: 000000
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655     HW: 8W0 959 655
   Component: Airbag10.44   H72 0086
   Serial number: 003M60045RN4
   Coding: AACCF0C00C800000585400F3C08C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
   VCID: 06546A76B8A4B27B9DD-8052
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: -----------    HW: 442 061 205 16
   Component: SideSensor_Df  1E2 0887
   Serial number: 3577Y009B1F4FCB2F13Q
   Coding: 2D2D2D
   Front Passenger's Side Airbag Crash Sensor:
   Subsystem 2 - Part No SW: -----------    HW: 442 061 105 16
   Component: SideSensor_Pf  1E2 0887
   Serial number: 3587Y009D1DE13F14237
   Coding: 2D2D2D
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 904 16
   Component: SideSensor_Dr  1C7 0148
   Serial number: 35177009F205BA55F15K
   Coding: 2D2D2D
   Passenger side rear thorax airbag crash sensor:
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 604 16
   Component: SideSensor_Pr  1C7 0148
   Serial number: 352770016293A82595FD
   Coding: 2D2D2D
   Crash sensor for front airbag: driver side:
   Subsystem 5 - Part No SW: -----------    HW: 442 0C0 405 16
   Component: FrontSensor_D  1C5 014A
   Serial number: 3557500B120BEED1610D
   Coding: 2D2D2D
   Crash sensor for front airbag: front passenger side:
   Subsystem 6 - Part No SW: -----------    HW: 442 0C0 405 16
   Component: FrontSensor_P  1C5 014A
   Serial number: 3567500B120BEED511ER
   Coding: 2D2D2D
   Center pedestrian protection crash sensor:
   Subsystem 7 - Part No SW: -----------    HW: 442 0C0 405 16
   Component: PedP_Sensor_C  1C5 014A
   Serial number: 2307500AD20DD1E223DH
   Coding: 2D2D2D
   Driver's side crash data pedestrian protection 2:
   Subsystem 8 - Part No SW: -----------    HW: 442 430 905 16
   Component: PedPSensor_D2  256 0887
   Serial number: I0M9M00BB1F6314283CJ
   Coding: 2D2D2D
   Passenger's side crash data pedestrian protection 2:
   Subsystem 9 - Part No SW: -----------    HW: 442 430 905 16
   Component: PedPSensor_P2  256 0887
   Serial number: I0N9M00BB1F63140E23E
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels: 4M0-907-129.clb
   Part No SW: 4M0 907 129 HA    HW: 4M0 907 129 HA
   Component: Lenks.Modul   H11 0009
   ASAM Dataset: EV_SMLSKLOAU736 006008
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 76B41AB6C844A2FB8DD-8022
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
   Part No SW: 8W5 920 941 A    HW: 8W5 920 941 A
   Component: MMA4M17DIEUK  H06 0363
   Revision: 0339v7      Serial number:    PY5FGDN5S
   Coding: 24A4509028800600012069601000000000000000
   ASAM Dataset: EV_DashBoardAU736 001022
   ROD: EV_DashBoardAU736_AU49.rod
   VCID: 3E24C296A0F42ABB95D-806A
Address 19: CAN Gateway (J533)       Labels:* None
   Part No SW: 4M1 907 468 C    HW: 4M1 907 468 A
   Component: Gateway       H15 0097
   Revision: 4R030001    Serial number: 0144R02A416514
   Coding: 0301000100008E40410700000059001248080007000000000100000000000000
   GVL: 01503C0800040200408C00000000480000080000000000000000000000000000
   ASAM Dataset: EV_GatewCONTIAU736 002060
   ROD: EV_GatewCONTIAU736_002_AU49.rod
   VCID: 372AD7B28FCE1BF356B-8062
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 8W0 951 523 C    HW: 8W0 951 523 C
   Component: J453 MFL  H02 0002
   Serial number: 20160520095843 01307
   Battery Monitoring Control Module:
   Subsystem 2 - Part No SW: 8S0 915 181 C    HW: 8S0 915 181 C
   Component: J367-BDMHella  H10 9070
   Serial number: 0988090404
Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0023
   ASAM Dataset: EV_LCMLeftHELLAAU736 001012
   ROD: EV_LCMLeftHELLAAU736_VW48.rod
   VCID: 78A8148EC250D48B9F1-802C
Address 2B: Steer. Col. Lock (J764)       Labels:* 5Q0-905-861.clb
   Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
   Component: ELV-MLBevo    H05 0032
   Serial number: 16000075784010
   Coding: 0000000000000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_ELVMarquMQBB 001007
   ROD: EV_ELVMarquMQBB.rod
   VCID: 323CE6A664ACFEDB615-8066
Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
   ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 42: Door Elect, Driver (J386)       Labels:* None
   Part No SW: 8W0 959 593 G    HW: 8W0 959 593
   Component: TSG FS        005 0052
   Serial number: 0000200702182
   Coding: 005F9A214001000000001082
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_AU37.rod
   VCID: 4EC492561054BA3B65D-801A
Address 44: Steering Assist (J500)       Labels:* None
   Part No SW: 8W0 909 144 F    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0407
   Coding: 09000380008000
   ASAM Dataset: EV_EPSZFAU49X 002015
   ROD: EV_EPSZFAU49X_002.rod
   VCID: 40D8BC6EDA005C4BE71-8014
Address 46: Central Conv. (J393)       Labels:* None
   Part No SW: 8W0 907 064 BC    HW: 8W0 907 064 C
   Component: BCM2 MLBevo   018 0327
   Coding: 012D00006F100000630180000E00000031024010004302500F0400000104803F001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 011012
   ROD: EV_BCM2HellaAU736_011_AU49.rod
   VCID: 7EA40296E074EABBD5D-802A
   Anti-theft alarm system sensor:
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY161160WHQ
   Alarm horn:
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000035504126
   Rear lid opener control module:
   Subsystem 3 - Part No SW: 3AA 962 243 G    HW: 3AA 962 243 G
   Component: GEB.F.Heckoef  H16 0903
   Serial number: 84389598
1 Fault Found:
131115 - Touch Sensor on Exterior Door Grip; Rear Right
          B116E 13 [009] - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 203
                    Mileage: 70104 km
                    Date: 2022.02.18
                    Time: 18:23:22
                    Supply voltages-Terminal 30 power supply: 12.066 V
                    Supply voltages-Supply voltage Terminal 30 - 2: 12.038 V
                    Supply voltages-Supply voltage Terminal 30 - 3: 12.011 V
                    general_additional_freeze_frame-Ambient_temperature_not_filtered: -50.0 °C
                    general_additional_freeze_frame-coprocessor_spi_status: 00000000
                    general_additional_freeze_frame-dataflash_status: 00000000
                    general_additional_freeze_frame-interior_temperature: -50.0 °C
                    general_additional_freeze_frame-Operating_Status: 00000000 00000000
                    general_additional_freeze_frame-production_mode: not active
                    general_additional_freeze_frame-reset_cause: 00000000
                    general_additional_freeze_frame-Reset_counter: 0
                    general_additional_freeze_frame-Stall_current_cutoff_level: Deactivation stage 0
                    general_additional_freeze_frame-Stall_Current_Measuring_Mode: not active
                    general_additional_freeze_frame-subnetwork_status: 00000000 00000000
                    general_additional_freeze_frame-terminal_control_intern_status: 91 04 0A 18 00 00
                    general_additional_freeze_frame-Transport_Mode: not active
                    general_additional_freeze_frame-Vehicle speed: 0.00 km/h
                    exterior_handle_sensor_freeze_frame: 00000000 00000000 11111111 00000000
Address 47: Sound System (J525)       Labels:* None
   Part No SW: 8W0 035 465     HW: 8W0 035 465
   Component: MIB2_amp_P_B9 H11 0420
   Revision: 00000001    Serial number: AUZ8ZAGJA001PSC
   Coding: 0194010800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI.rod
Address 52: Door Elect, Pass. (J387)       Labels:* None
   Part No SW: 8W0 959 592 G    HW: 8W0 959 592
   Component: TSG BFS       005 0052
   Serial number: 0000200735000
   Coding: 005F9A214001000000001080
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_AU37.rod
   VCID: 4DC6955A1D5281231C7-8018
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGS2.clb
   Part No SW: 8W0 035 192 A    HW: 8W0 035 192 A
   Component: MU-HS-LND-EU  045 0148
   Serial number:
   Coding: 019401010000000013111102000A00102F0001E601F00100CE
   ASAM Dataset: EV_MUHigScl6C3DELP 001011
   ROD: EV_MUHigScl6C3DELP.rod
   VCID: 3430E0BE9EB8F0EB739-8060
   Data carrier:
   Subsystem 1 - Part No SW: V03 959 802 LE    HW: -----------
   Component: ECE 2019/2020  --- 0043
   Serial number: --------------------
   Multimedia System 1:
   Subsystem 2 - Part No SW: 8W2 919 604     HW: 8W2 919 604
   Component: AU49x_DU_STD  H40 0008
   Serial number: AUZ8Z9GBH009QS
   Multimedia system control head:
   Subsystem 3 - Part No SW: 8W0 919 614 J    HW: 8W0 919 614 J
   Component: ControlUnit_B  H21 0134
   Serial number: APVAK102051600030012
Address 82: Head Up Display (J898)       Labels:* None
   Part No SW: 8W5 919 617 C    HW: 8W5 919 617 C
   Component: HeadUpDisplay H15 1603
   Coding: 2A01C0
   ASAM Dataset: EV_HudNSEIKAU736 001015
   ROD: EV_HudNSEIKAU736_AU49.rod
   VCID: 48C8A44EF230640B2F1-801C
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W0 907 217 B    HW: 8W0 907 217
   Component: BVS           H14 0042
   Coding: 0404090100000403024023A0A40000FC00F0C020C000
   ASAM Dataset: EV_BVSMLBevKOSTAAU736 002026
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: 3B22CB82B3E63F93B23-806E
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355     HW: 4M0 907 355
   Component: SCR-Stg-G3H10 0003
   ASAM Dataset: EV_RDCMINERGAU736 005009
   ROD: EV_RDCMINERGAU736_AU49.rod
   VCID: 6E8432D6B0149A3B45D-803A
6 Faults Found:
0259 - Control Module for Reductant Metering System; Voltage Suppy
          P21CA 00 [013] - Electrical Malfunction
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 70183 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Terminal 30A voltage: 0.00 V
                    Terminal 30B voltage: 0.01 V
                    Supply voltage for external components: 4.99 V
                    Reducing agent quality sensor: voltage terminal 31: 0.00 V
                    Pump for reducing agent: speed: 0 /min
                    Pump for reducing agent: current: 0.00 A
                    Reducing agent pump: operating state: OFF
                    Reducing agent pump: activation: 0.00 %
                    Reducing agent pump: end stage activation status: not active
                    Reducing agent pump: end stage temperature: 1 °C
                    Heating circuit 1 f. red. agent metering sys.: end stage temp.: 1 °C
                    Sensor for reducing agent tank temperature: temperature: 7 °C
                    Pressure sensor for reducing agent: voltage: 0.71 V
                    Sensor for reducing agent fill level: fill level height: 65515 mm
                    Reducing agent quality sensor: urea concentration: 107.00 %
                    Sensor 2 for temp. reducing agent: act. value: -45.00 °C
                    Heating circuit 1 for reducing agent: power: 0 W
                    Heating circuit 1 for reducing agent: power set value: 0 W
                    Heating circuit 1 for reducing agent: power limitation: 142 W
                    Heating circuit 3 for reducing agent: power: 0 W
                    Heating circuit 3 for reducing agent: power set value: 0 W
                    Heating circuit 3 for reducing agent: power limitation: 59 W
                    Heating circuit 2 for reducing agent metering: power: 0 W
                    Heating circuit 2 for reducing agent metering: activation: not active
262400 - Control Circuit for Reductant Heating 1
          P20BC 00 [008] - Short to Plus
          [SCR_Tank_Heater_Shortcut_to_Vbat]
          Intermittent - Confirmed - Tested Since Memory Clear
262656 - Control Circuit for Reductant Heating 3
          P20C4 00 [008] - Short to Plus
          [SCR_Tank_Heater_2_Shortcut_to_Vbat]
196608 - Control Circuit for Reductant Pump 1
          P208D 00 [008] - Short to Plus
          [SCR_Dosing_pump_Shortcut_to_Vbat]
0003 - Control Module for Reductant Metering System; Voltage Suppy
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 70183 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Terminal 30B voltage: 0.00 V
196612 - Control Circuit for Reductant Pump 1
          P208C 00 [008] - Short to Ground
          [SCR_Dosing_pump_Shortcut_between_phase]
Address BB: Door Rear Drv (J388)       Labels:* None
   Part No SW: 8W0 959 595 G    HW: 8W0 959 595
   Component: TSG HFS       005 0052
   Serial number: 0000202108446
   Coding: 000F98200001000000001080
   ASAM Dataset: EV_DCU2RearDriveMAXHCONT 001005
   ROD: EV_DCU2RearDriveMAXHCONT_AU37.rod
   VCID: 50F88C2E0A60ACCB771-8004
Address BC: Door Rear Pass (J389)       Labels:* None
   Component: TSG HBFS      005 0052
   Serial number: 0000202108497
   ASAM Dataset: EV_DCU2RearPasseMAXHCONT 001005
   ROD: EV_DCU2RearPasseMAXHCONT_AU37.rod
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
   ROD: EV_LEDModLeftMELCOAU736_VW37.rod
   VCID: 16743A36E80402FB6DD-8042
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H09 0003
   ASAM Dataset: EV_LEDModRightMELCOAU736 001004
End----------(Elapsed Time: 01:45, VBatt start/end: 13.2V/13.2V)-----------
Now i tried to take on motorway while forcing regen according to ross tech website but still not resolved.
i also saved this information if this helps after 2 hours of driving on 3rd gear and above 2500-3000revs.
IDE00432   Particle filter: time since last regeneration 23.369 H
  IDE00434   Particle filter: soot mass calculated 44.65 g
  IDE00435   Particle filter: soot mass measured -2.44 g
  IDE00436   Particle filter: kilometers since last regeneration 414.8 km
  IDE06059   Particulate filter: oil ash mass 22.3329579 g
Edited by aakayamy79
needed to make adjustment to my post
52 minutes ago, aakayamy79 said:
Hi everyone.
Need some help.
          BB BC D6 D7
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 70178 km
                    Date: 2022.02.19
                    Time: 21:31:13
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 70125 km
                    Date: 2022.02.19
                    Time: 20:40:56
   CVN: B0FDBA67
   Coding: 5BC7F7
   Coding: 02005D
   Light switch:
   Coding: 230000
   Coding: 000000
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Alarm horn:
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 203
                    Mileage: 70104 km
                    Date: 2022.02.18
                    Time: 18:23:22
   Serial number:
   Data carrier:
   Coding: 2A01C0
6 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 70183 km
                    Date: 2000.00.00
                    Time: 00:00:00
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 204
                    Mileage: 70183 km
                    Date: 2000.00.00
                    Time: 00:00:00
Hi most Adblue deletes are legally sold on the understanding that the the car will not be driven on public roads therefore they are able to do it, lots of people have this done which is fine until the government introduce the new legislation and particle analysing equipment in to the MOT system, its coming, the Adblue helps with regeneration of the DPF, which in your case allied to the extra fuel used with the remap and the lack of Adblue may result in the regeneration cycle not being of sufficient duration to clear the soot particles and as Audi use a very low soot/ash calculation will cause it to block more quickly so try a forced regeneration as from your data the fault has only occurred once.
I've tried a forced regen while driving and parked but both get timed out after one hour. I've tried the Ross tech methods for the Audi but no luck what so ever.
Hi the timing out is so you don't cook the car, did you delete the light and codes before trying to regen as it won't work with the light/codes still present, delete and try again also did you have a look at the soot/ash loadings after the run.
The soot loadings on my first post at the bottom are from after the last regen I tried to do before it cut out.  Showing minus
Hi sorry what are your current Soot/Ash loadings and what has cut out am a bit confused.
Hi second one down is what it thinks its got, the third one down is what its got real time, this is really strange also is the DPF light still on? and is all the reductant pump information still present.
Yeah all that is still present. Not sure if I should bite the bullet and change the dpf sensor and then try doing regen again as the calculated soot level showing 44.65g and measured mass soot showing -2.44g. I've tried clear codes but the engine dpf codes won't clear so didn't do a regen again as I'm guessing it will time out again after 1 hour.
Have you got a code for the DPF sensor as this will show as reading high. Also is it VCDS you are using as the live data for the sensor should give you an indication of its operating values.
Thinking about it it could well be the DPF pressure sensor as the ECU uses that and algorithm to do a soot mass calculation and for what a decent sensor costs its worth a go.
I'm using a genuine Ross tech VCDS hex-v2 with the latest vcds software. Im not getting any error codes for the sensor but I'm tempted to replace the sensor and then see if it helps clear the codes and also force regen.
11 minutes ago, aakayamy79 said:
I have two of these sensors. This is the front one and other one is behind this.
Hi I am certain you only have the one shown as  that has both pipes for measuring the pressure before the DPF and after the DPF there would be no point in having two sensors I suspect the one behind might only have one pipe and that would be to do with boost control or MAP pressure.
19 minutes ago, aakayamy79 said:
Hi you have lost me just looked on ETKA generic part finder and the the diagram only shows one unit for that year of vehicle but your pictures say otherwise so therefore it would seem you may well have to change and re adapt both. According to my Autodata fault finder excessive soot calculation is a classic sign of sensor failure.
I searched online myself and only see one of them sensors but when I seen two sensors in mines i was just as confused. I will speak to A4audi who did my adblue delete and remap tomorrow and see what they say first and if no luck then will fit two sensors myself and see how I get on  20220219_125524.thumb.jpg.8a71c69da2b30af8bec87e036b991be0.jpg
Took car back to A4AUDI and they did regen and that sorted out the issue. Hopefully that will be the end of it. Thanks for helping.
Hi did you find out why it has two sensors as the only thing I could think of was is it a V6.
I honestly don't know why I have two sensors and I didn't ask the garage I fit the regen done from.  But am glad my problem is sorted.
