Pwm Posted February 22, 2022 Posted February 22, 2022 Hi. Replaced egr valve after getting engine management light on and fault code p040100 coming up on code reader. After changing egr reset code and engine management light went out then came back on after few days.Plugged code reader in and fault code p040100 was back up. After a bit of research online replaced the dpf sensor as heard this could cause the fault code. Again reset the code and was fine for couple days but fault code is back again and engine management light is back on.Anyone got any ideas. Thanks Paul
evopilot Posted February 23, 2022 Posted February 23, 2022 the fault is in relation to lack of air flow detects at the EGR so if you have replaced the EGR itself id be taking off and cleaning the pipework as far upstream and downstream as possible from the EGR
Pwm Posted February 23, 2022 Author Posted February 23, 2022 Yip done all that when EGR was changed wasn’t to bad to be honest. Think the next idea would be to check for any vacuum leaks, have you had any known issues with a vacuum leak at certain places as it could be a good point to start where people have had issues before. Thanks paul
Stevey Y Posted February 24, 2022 Posted February 24, 2022 On 2/22/2022 at 10:12 PM, Pwm said: Hi. Replaced egr valve after getting engine management light on and fault code p040100 coming up on code reader. After changing egr reset code and engine management light went out then came back on after few days.Plugged code reader in and fault code p040100 was back up. After a bit of research online replaced the dpf sensor as heard this could cause the fault code. Again reset the code and was fine for couple days but fault code is back again and engine management light is back on.Anyone got any ideas. Thanks Paul Hi did you readapt the new EGR and sensor as this would cause the fault to re surface as the ECU only has the old adaptation values stored, when readapting is in place the ECU learns the new values as it goes along the drive cycles and absorbed those as the new operating parameters. Steve.
Pwm Posted February 24, 2022 Author Posted February 24, 2022 Hi stevey. Had it checked out at a garage today and they have said it’s a faulty EGR valve so they are going to fit new one tomorrow so hopefully it cures the problem. thanks paul
Stevey Y Posted February 25, 2022 Posted February 25, 2022 18 hours ago, Pwm said: Hi stevey. Had it checked out at a garage today and they have said it’s a faulty EGR valve so they are going to fit new one tomorrow so hopefully it cures the problem. thanks paul Hi Paul thats a bit of savage luck, I have come across a few new wrong-un EGRs in my time mostly from Eurocarparts and some Valeo units known as the French revenge, I hope the new one has solved the problem. Steve.
Milan punak Posted August 20, 2023 Posted August 20, 2023 Egr P040100 code cleaned change breath pipe but engine light came on next day can anyone help pls the car pulls good drives good don't understand
