I have an A3 8v 2013 2.0tdi, does anyone know why i i use 500ml of water but only on long journeys. I can go to work everyday and not lose a drop of water, had the car into garage and there are no leaks, had the head and cooling system pressure tested, and both ok. Any idea's
Hi possibly the header tank cap as the seals deteriorate with age and let by water vapour when the water temperature is high for prolonged periods.
Hi Steve, the car temp gauge stays at normal, would the cap still leak vapour do you know, many thanks
Hi yes the cap could still leak as you won't have used sufficient coolant to cause it to boil as the pressure loss is one way which is out as a fine mist I have even had it where the cap locks down and over pressurises the system and caused the thermostat housing to leak, for what a new cap is its worth trying.
  • 3 months later...
Hi,
Did you replace the cap? and did this fix the problem?
Ste
On 6/30/2022 at 10:01 PM, SteTB said:
Hi,
Ste
Changed the capand it didn't nothing, it worked out it was the exhaust manifold matrix causing the fault. Cost of repair was over £2500
