tomsta79 Posted March 14, 2022 Posted March 14, 2022 Hi there I've got a audi a4 b7 2.0 tdi engine code brb . Had a ticking noise for a month are so read some were it could be the lead plugs coming out of injector rockers . Are could be a lifter are some thing . Does my engine only have a single camshaft enigne code is brb . And been told to check if its intake are exhaust camshaft which am not sure any help on this thanks
Steve Q Posted March 15, 2022 Posted March 15, 2022 Hi there, isn't the brb a 1.9tdi? The camshaft or valves could be worn especially if it's run low on oil. what's the mileage on it?
tomsta79 Posted March 15, 2022 Author Posted March 15, 2022 1 hour ago, Steve Q said: Hi there, isn't the brb a 1.9tdi? The camshaft or valves could be worn especially if it's run low on oil. what's the mileage on it? Sorry was wrong engine code right code is BLB . Low mileage 134k. Its not flywheel when clutch is in are out still sounds the same . If its camshaft are lifters could I just buy full new fit .is it a single cam on these engines as not sure thanks
tomsta79 Posted March 15, 2022 Author Posted March 15, 2022 1 minute ago, tomsta79 said: Sorry was wrong engine code right code is BLB . Low mileage 134k. Its not flywheel when clutch is in are out still sounds the same . If its camshaft are lifters could I just buy full new fit .is it a single cam on these engines as not sure thanks 2.0 tdi .BLB
