Steve Q Posted March 15, 2022 Posted March 15, 2022 As per the title the main water ingress culprit into the cabin is from the battery tray housing. causing wet carpets and if left untreated can damage the CCM which sits in the passenger from footwell. This picture shows how to clean out the tray and unblock the drain holes which get clogged with foliage and dirt. Bare in mind another culprit is a cracked pollen filter housing.
