hi all,im in trouble again with my TT!!im wondering does anyone know where i can get the main brake pipe from the master cylinder to the abs pump,theres 2 pipes but one of mine is leaking just below the resevoir,a very awkward pipe to change but appearantly a common fault,ive had no luck on eBay so any suggestions are very welcome,thanks greg.
Hello Gregg,
Any reputable garage should be able to make and fit brake pipes to the correct pattern.
Posted (edited)
thanks for the advice gareth,ive sourced the part off a chap breaking a tt so im off to collect it tomorrow,thanks again.
greg
Quote
Quote
Edited by coupe4
spelling errors
Thanks Gregg,
Apologies, but would I fit a secondhand brake pipe instead of getting a new one professionally made up -??
hi gareth,its a coincidence you say that as i been thinking the same thing and decided last night to get a new pipe made up,my only concern is that its a thicker pipe than the standard ones that feed the calipers and im hoping i can find a garage with the right equipment,thanks again.greg.
