Fay Posted March 22, 2022 Posted March 22, 2022 Hi there. My Audi lost all audio output and a new unit was recommended. I purchased one with exact same part number but when fitted only half the speakers work and on radio it cuts out for a second every few seconds (doesn’t do this on phone, satnav, cd etc). Does it need to be programmed at Audi or should it just plug and play please? Thanks for any help you can offer. Car is 2013 A5 Quattro and replaced part number is 4g0035056g
Stevey Y Posted March 23, 2022 Posted March 23, 2022 21 hours ago, Fay said: Hi there. My Audi lost all audio output and a new unit was recommended. I purchased one with exact same part number but when fitted only half the speakers work and on radio it cuts out for a second every few seconds (doesn’t do this on phone, satnav, cd etc). Does it need to be programmed at Audi or should it just plug and play please? Thanks for any help you can offer. Car is 2013 A5 Quattro and replaced part number is 4g0035056g Hi it is more than likely a coding issue, was the new unit second hand? if not it will still need coding. Steve.
Fay Posted March 24, 2022 Author Posted March 24, 2022 12 hours ago, Stevey Y said: Hi it is more than likely a coding issue, was the new unit second hand? if not it will still need coding. Steve. Thanks so much Steve! It was 2nd hand. I guess that will have to be an Audi dealer will it?
Stevey Y Posted March 24, 2022 Posted March 24, 2022 13 hours ago, Fay said: Thanks so much Steve! It was 2nd hand. I guess that will have to be an Audi dealer will it? Hi not necessarily if you can find a kind soul in your area that has VCDS, try any independent VAG specialists as they may well be able to help you out and it will be a lot cheaper than Audi who charge an eyewaterinw amount just to inspect it. Steve.
