Asad Posted April 8, 2022 Posted April 8, 2022 (edited) Hi I have been having issues with my ABS/Traction and have identified its the yaw/acceleration sensor. I am looking for a replacement one however when I type In the control module part number there are many that come up e.g 4G0907637 H02 0009 4G0907637 H02 0004 4G0907637 H02 0056 my code only shows this number 4G0907637 not the H numbers. Do you know which one will correspond with mine. Its for at Audi A6 C7 2012 S line saloon any help please thanks Edited April 8, 2022 by Asad .
Stevey Y Posted April 9, 2022 Posted April 9, 2022 20 hours ago, Asad said: Hi I have been having issues with my ABS/Traction and have identified its the yaw/acceleration sensor. I am looking for a replacement one however when I type In the control module part number there are many that come up e.g 4G0907637 H02 0009 4G0907637 H02 0004 4G0907637 H02 0056 my code only shows this number 4G0907637 not the H numbers. Do you know which one will correspond with mine. Its for at Audi A6 C7 2012 S line saloon any help please thanks Hi if the items you are looking at are the same as yours with only a different letter they will fit as the letter is just a manufacturer year designation. Steve.
Stevey Y Posted June 30, 2023 Posted June 30, 2023 6 hours ago, a6blacked007 said: We're is this sensor located? Hi think its under the centre console by the gear stick most of the yaw sensors and lateral acceleration sensors are mounted on the centre line of the car and will be grouped in the same housing. Steve. 1
