un1x Posted April 9, 2022 Posted April 9, 2022 Hello, 2005 model Audi - A4 1.6 ALZ engine started to give oil pressure warning in my vehicle. Image1: https://www.hizliresim.com/43px1i8 Image2: https://www.hizliresim.com/gfz5z4a oil pressure Stop the engine and check the oil level. The fault light comes on after 1100 - 1200 rpm. - The oil and oil filter of the vehicle were changed. - The oil switch has been changed. - The oil pressure was checked, it was said very well. I showed the vehicle to a few different places, it was said that there was no problem with the engine, they said there would be an electronic problem. In my mind, 2 days before this malfunction light came on, when I got into the car, I saw that the screen that gave a warning did not work at all. The next day, I started the car, the screen appeared, but I never got in. I got in the car in the morning on the way to work. It started giving this warning light. How can we solve this malfunction, where should we look.
Steve Q Posted April 9, 2022 Posted April 9, 2022 You've done a good level of diagnostic work. When I had a similar issue on my A6 I had an oil flush of the engine as well as the new oil and filter. This rectified the issue.
