Sarge B Posted April 9, 2022 Posted April 9, 2022 Hi I recently aquired a lovely 2018 70k mile A6 Diesel following the death of father in law. Drive likes new. I love the big old barge - but it has developed an issue with the drivers' seat belt - in that when it retracts it locks and wont come out - and then a few minutes later (normally after tugging at/jiggling it and/or drving 50m down the road) it releases as normal. Is this a common issue? and/or something that's easily rectified? I'm wondering if the pre-tensioner is engaging? (as it releases itself eventually) or if it's another common fault... Thanks in anticipation.
Sarge B Posted April 9, 2022 Author Posted April 9, 2022 On 4/9/2022 at 3:10 PM, Sarge B said: Hi I recently aquired a lovely 2018 70k mile A6 Diesel following the death of father in law. Drive likes new. I love the big old barge - but it has developed an issue with the drivers' seat belt - in that when it retracts it locks and wont come out - and then a few minutes later (normally after tugging at/jiggling it and/or drving 50m down the road) it releases as normal. Is this a common issue? and/or something that's easily rectified? I'm wondering if the pre-tensioner is engaging? (as it releases itself eventually) or if it's another common fault... Thanks in anticipation. Expand its a 2008 not 2018..!
Stevey Y Posted April 9, 2022 Posted April 9, 2022 On 4/9/2022 at 3:10 PM, Sarge B said: Hi I recently aquired a lovely 2018 70k mile A6 Diesel following the death of father in law. Drive likes new. I love the big old barge - but it has developed an issue with the drivers' seat belt - in that when it retracts it locks and wont come out - and then a few minutes later (normally after tugging at/jiggling it and/or drving 50m down the road) it releases as normal. Is this a common issue? and/or something that's easily rectified? I'm wondering if the pre-tensioner is engaging? (as it releases itself eventually) or if it's another common fault... Thanks in anticipation. Expand Hi there is a rolling ball device in the spool that the belt is wound onto which normally gets dry and full of gunge, if you remove the trim and hose it down with silicone spray it normally starts working again if you get it in the released position and work it back and forth so it revolves the spool whilst spraying, WD40 works better but it stinks for ages afterward. Steve.
Sarge B Posted April 14, 2022 Author Posted April 14, 2022 On 4/9/2022 at 5:51 PM, Stevey Y said: Hi there is a rolling ball device in the spool that the belt is wound onto which normally gets dry and full of gunge, if you remove the trim and hose it down with silicone spray it normally starts working again if you get it in the released position and work it back and forth so it revolves the spool whilst spraying, WD40 works better but it stinks for ages afterward. Steve. Expand That’s brilliant - I shall give it a go over the weekend. WD40 will probably smell better than me anyway…. 1
Sarge B Posted May 19, 2022 Author Posted May 19, 2022 On 4/9/2022 at 3:10 PM, Sarge B said: Hi I recently aquired a lovely 2018 70k mile A6 Diesel following the death of father in law. Drive likes new. I love the big old barge - but it has developed an issue with the drivers' seat belt - in that when it retracts it locks and wont come out - and then a few minutes later (normally after tugging at/jiggling it and/or drving 50m down the road) it releases as normal. Is this a common issue? and/or something that's easily rectified? I'm wondering if the pre-tensioner is engaging? (as it releases itself eventually) or if it's another common fault... Thanks in anticipation. Expand Madly soled it in a random way.... Ive got a wireless charger/holder for my phone... and if I put my phone in it first - it wont let me start the car (no lights even come on)... and it locks the seat belt tensioner... If I dont put it in the holder first - then I've not had it occur once... Must be a massive power drain causing some sort of issue...however if phone is plugged in via a normal cable it's fine....proper random...!
Steve Q Posted May 19, 2022 Posted May 19, 2022 How old is the battery? Failing batteries can cause all sorts of weird electrical issues. 1
Sarge B Posted May 19, 2022 Author Posted May 19, 2022 On 5/19/2022 at 8:25 PM, Steve Q said: How old is the battery? Failing batteries can cause all sorts of weird electrical issues. Expand Genuinely no idea - looks new and sadly can't ask the father in law anymore... Absolutely fine as long as I don't put the phone in the cradle first..
Steve Q Posted May 19, 2022 Posted May 19, 2022 On 5/19/2022 at 8:28 PM, Sarge B said: Genuinely no idea - looks new and sadly can't ask the father in law anymore... Absolutely fine as long as I don't put the phone in the cradle first.. Expand I'd get the battery checked as a priority. 2
RoyC Posted May 28, 2022 Posted May 28, 2022 On 5/19/2022 at 8:25 PM, Steve Q said: How old is the battery? Failing batteries can cause all sorts of weird electrical issues. Expand My old battery looked brand new as well, but it was thirteen years old (original battery) I was having trouble with doors not locking or unlocking, got a new battery and all is fine now. 😀
