Hi all, firstly thank you for admitting me, had my cab 3 yrs now, absolutely no issues whatsoever....
Until now, the cab roof has decided to pack up.
I raised the roof halfway and stopped it, while I cleaned the seals, whilst distracted it came down under its own weight,  I switched back on and it closed as normal.  Then rained for a month.....
Came to use it, windows retracted, roof released, then nothing..
Dash display  "roof cannot be used"
Any tips, or know of a technician in the Manchester area??
Best regards
Garry
If it's hydraulic operated I wonder if the roof coming down on its own under the weight and pressure has damaged the pump. Is there any noise from the pump? Also id recommend a diagnostic check to see if there's any fault codes.
