p00af00 - turbocharger/supercharger boost control "a" module performance
Driving quite quickly home last night - then the coil light comes on, flashing. Because phone is playing spotify I can ask it to tell me what it means! I get some generic stuff, but at least I know - as it drops in to limp mode - I'll get home.
So, home and scan. I get the p00af00 - turbocharger/supercharger boost control "a" module performance. I've looked this up and I am hoping it's just the boost control module.
If I clear codes, the car is fine when I start it - but if I rev it the flashing begins.
Anyone else had experience of this, and the possible cost 😞
Hi Thomas its the control module on the turbo which will be either vacuum controlled or an electrical control box my guess is its vacuum and not holding the pressure and depending on your model of turbine the units are available as a replacement for around £70-100.
Hi Thomas I did a bit of digging and yours is one of the famous Hella electronic control boxes not vacuum, and it looks like a doable job just beware of the micro circlip on the actuator linkage, TPS do a repair kit for a lot of Groats but there are people on the net who offer a repair service, a lot cheaper, apparently your unit suffers the same problem as the Fords did with the circuit board inside fails or the Cr@ppy plastic gears strip.
Thanks!!
It's booked in for Monday/Tues. Any links would help. The garage is good at going with pointers.
It didn't come on just now when I reversed. I even blipped the revs.
But it needs to be looked at.
I'll let you know.
Crappy plastic gears. What !Removed!.
Took the garage a wee bit to find this, even though I mentioned it. But they also caught a failing solenoid.
Attached is pic of those !Removed! plastic parts. Worn worm screw and teeth chipped off the gear.
So much for a "glow-plug" warning!
Hi Thomas the Ford ones were a bit different they had bigger gears with more teeth to strip I rebuilt a couple of mine but ended up buying a new unit it was cheaper than keep buying repair kits which only lasted about 40k, they are a real engineering atrocity.
  • 11 months later...
Do you have a part number for this part? I'm getting the same kind of issue. Just want to check prices and then can give my mechanic a heads up on what to look out for. TIA
I did keep it.. Part number: 6NW 009 550
Good luck!
Did you fix it? I have the same problem… only when the turbo gets hot I think. How did you solve it?
Hi if you read the post in depth it tells you and shows you the box that he replaced on the turbo and has the added bonus of the part number.
  • Thanks 1
  • 10 months later...
Hy,
I have the same type of car and it gives me the same error. I am waiting for the part with 6NW 009 550 to arrive and to change it
I have a question
does the part 6NW 009 550 need to be programmed again or did you just change the part and that's it?
Thank you for an answer.
The garage changed it - but it shouldn't need coding.
  • 6 months later...
Hi all,
I was driving yesterday and not at any pace really, but got similar symptoms to above. Glow plug light flashing and car went into limp mode.
I took it to a mates garage and got three codes showing:
P004700 TURBO BOOST CONTROL A SOLENOID CIRCUIT LOW
P334800 ACTIVATION TURBO CONTROL MODULE 1 J724 ELECTRICAL MALNFUNCTION IN CIRCUIT
P00AF00 TURBO BOOST CONTROL A MODULE PERFORMANCE (2 OF THESE)
My friend reset the codes and we had a quick look for any damaged wires or obvious signs but when i then drove gently up the road at 30mph, the flashing started again within about 300 metres.
Not sure where to go with it but really disappointed having come back to a BiTdi after selling an a6 allroad a coupe of years ago. This is a 90k miles saloon 2013 model, s line and came from a good friend who had it for about 6 years.. who i trust implicitly.
Any thoughts please
Look at the thread above. It will be the useless plastic teeth problem ...
Goo luck
Goo luck
Thank you - from what i understand from reading various forums, this might need calibration? Just wondering whether i should get this done at a place that can calibrate it. This part number? 6NW 009 550
  • 4 months later...
Hi all, I know this is an older thread but just looking for some advice. I have a 2010 Audi A3 and I have the same flashing coil light. The error code on my basic reader is P00AF and also P2563 "turbocharger boost control position sensor A circuit".
From what I can gather, I suspect I may have the same problem as the original author of the thread. I have it booked in with a VAG specialist this week. Any tips on how not to be fobbed off and ideas on costs would be much appreciated.
Hello, the system flagged you'd replied to this thread.
Stevey Y was correct. You could try to replace yourself as they will charge you for !Removed! diagnostics now. I foolishly didn't include the part number in the photos...
Good luck, and just tell them, the teeth will be off it, and it just needs replacing...as they suck through theirs and shake their heads...
Thanks for the swift reply. I did a bit of digging on the part that you replaced and it looks like that isn't compatible with my motor. Instead my turbo has a vacuum type pressure valve which looks to be a fairly easy (and cheap) fix. I'm going to give this a try before going to the specialist. With a bit of luck, this will solve it. It's either between this or the pressure sensor, again, a cheap part to buy so I've ordered both. Let's see how it goes.
