Steve Q Posted April 18, 2022 Posted April 18, 2022 All you need is a Torx 20 bit, a flat blade or trim removal tool and some brute force!! Top tip is to wind the window down to give you easier access when removing the door card First you need to remove the aluminium (or whatever colour) trim by the door handle using the flat blade to reveal the two hidden screws Back of removed trim so you can see the clips. Then undo the screw below the door handle. Next is to the flat blade at the bottom and start levering towards you. Once you can get your hands in simppy work your way around to the top. Don't be afraid to use a bit of brute force Pic of the back of the door card showing the various clips Then pull the door car up and start unclipping the plugs and door handle Top is the speaker cable Unclip the Yellow clip for the door handle cable Finally undo the connector that goes into the door control module at the bottom (bottom of the pic) Fitting is reversal of removal!! Clip the plugs and door handle cable back in Then lift the door card back onto the lip at the top; having the window down as far is goes makes this step a little easier! Put the screws in Tap the clips back into place Job done Hope this helps Rhys on Audi-sport.net 1 1
