Jeaningo Posted April 20, 2022 Share Posted April 20, 2022 Hello Folks I just intend to buy a set of le mans 19 alloy wheel for my a6c6 Do they have all they same center bore 5x112 because for the a6 I see only this measurements and what kind of bolts length can I use audi a6 standart alloy wheel Thanks Jean Quote Link to comment Share on other sites More sharing options...
Steve Q Posted April 20, 2022 Share Posted April 20, 2022 Hi Jean I believe they should be a direct fit with no modifications required. Quote Link to comment Share on other sites More sharing options...
Jeaningo Posted April 21, 2022 Author Share Posted April 21, 2022 Hello Steve Thanks for the quick response I just got the info there are 255/35/19 fitted do I get there a problem with the wheel arch the audi is not lowered. Thanks jean Quote Link to comment Share on other sites More sharing options...
Steve Q Posted April 21, 2022 Share Posted April 21, 2022 I think you should be fine. But 18" will give you a better ride in my opinion. Quote Link to comment Share on other sites More sharing options...
RoyC Posted May 25, 2022 Share Posted May 25, 2022 I have just fitted the 7 double spoke Lemans wheels to my A6 C6 Avant. 19" x 8½"J Tires 19 x 255 x 35 fronts 45psi and rears 40 psi, no rubbing problems If there are potholes in your area don't be tempted to run lower pressures unless you want your rims damaging. Quote Link to comment Share on other sites More sharing options...
Jeaningo Posted May 26, 2022 Author Share Posted May 26, 2022 Hi I haven't made a decision yet between le mans and bbs lm but many thanks for the info 1 Quote Link to comment Share on other sites More sharing options...
