Steve Q Posted April 20, 2022 Posted April 20, 2022 Check out how to install the Audi Apple CarPlay module. First of all need to take off main MMI component & air climate panel. Audi Q3 RMC unit To pull off this unit, you’ll need VW radio removal tools. VW radio removal tools Insert VW removal tools inside the two holes in each side of MMI unit. You will hear a “click” noise, then you can pull off whole unit. After that disconnect all cables from unit. Now we need to make few changes to have a sound coming from CarPlay to MMI (the hardest part – we recommend to do this via advanced installers). NOTE!! THIS IS ONLY FOR AUDI Q3 OWNERS!! IN A6 / A1 DO NOT NEED DOING THIS!!! YOU ONLY NEED TO HAVE AUX After that, you need take off climate control panel as will need put cable spliter there. The best way to remove it, is using trim removal tools on each side: Audi Q3 climate control panel removal Audi Q3 climate control panel removal and pull it off. Another step is to connect all cables like on this diagram and the last one is to check if everything works fine! hope this has helped link: https://carsie.net/tutorials/apple-carplay-installation-manual-for-audi-a1-a3-q3-rmc-units/ 🙂
