Hi guys,
What mm did people lower their standard 8p sline's and what would you recommend, would 35mm be too low ? Thankyou
35mm should be fine. Go for a springs and shocks package not just lowering strings. Bilstein kits are supposed to be very good (b12 pro)
What shocks will be best to lower it with , are the sline shocks ok?
What spec is yours? If it's an se or similar then fitting s line suspension should lower it my 20mm if I remember correctly as s line suspension is shorter and stuff than non s line suspension.
The next drip you can go is to 30 or 35mm with aftermarket kits.
