If you are having trouble with your indicators or hazard lights it could be due to a failing indicator relay which is part of the hazard warning light. Audi part no. 4b0941509DB98. Cost £22.78 from Audi.
Here's a guide on how to remove the old and replace it with the new.
So here goes:
Use a small thin screwdriver to gently prize off the dash surround around the hazard warning light switch and cupholder. Then use a flat screwdiver to prize out the hazard warning switch towards you away from the dash. Unplug the din adapter at the back and replace with the new. refit the dash surround.
Simple job and took about about a minute.
Hope this helps if any of you come across this fault.
