rear coil spring locator ?
blondin4o
Hi i just fail on MOT and 1 of the reason was
  • Offside Rear Coil spring fractured or broken spring locator also missing (5.3.1 (b) (i))
any idea what part is that because i can't find by that name i got audi a6 2006 avant 2.7 manual.
Hi its most likely the turret that is attached to the rear lower arm which means you will have to buy a new arm, alternatively it may be the top spring rubber mount which is also replaceable, a picture would tell the correct story.
they show me some piece of rubber which was damage and moving inside on the coil spring. i forgot to make a picture. i found mount rubber but have bottom and top rubber...
Edited by blondin4o
Hi buy the top and bottom rubber mounts, new spring job done, I would seriously think about getting both rear springs and mounts done as they wear as a set.
