blondin4o Posted April 26, 2022 Posted April 26, 2022 Hi i just fail on MOT and 1 of the reason was Offside Rear Coil spring fractured or broken spring locator also missing (5.3.1 (b) (i)) any idea what part is that because i can't find by that name i got audi a6 2006 avant 2.7 manual.
Stevey Y Posted April 26, 2022 Posted April 26, 2022 19 minutes ago, blondin4o said: Hi i just fail on MOT and 1 of the reason was Offside Rear Coil spring fractured or broken spring locator also missing (5.3.1 (b) (i)) any idea what part is that because i can't find by that name i got audi a6 2006 avant 2.7 manual. Hi its most likely the turret that is attached to the rear lower arm which means you will have to buy a new arm, alternatively it may be the top spring rubber mount which is also replaceable, a picture would tell the correct story. Steve.
blondin4o Posted April 26, 2022 Author Posted April 26, 2022 (edited) they show me some piece of rubber which was damage and moving inside on the coil spring. i forgot to make a picture. i found mount rubber but have bottom and top rubber... Edited April 26, 2022 by blondin4o
Stevey Y Posted April 26, 2022 Posted April 26, 2022 1 hour ago, blondin4o said: they show me some piece of rubber which was damage and moving inside on the coil spring. i forgot to make a picture. i found mount rubber but have bottom and top rubber... Hi buy the top and bottom rubber mounts, new spring job done, I would seriously think about getting both rear springs and mounts done as they wear as a set. Steve.
