No I do t believe they will. You should be able to get the A4 b7 ones without trouble.
21 hours ago, Beany1 said:
What engine mounts will fit
Hi you really should start surfing the net for part numbers there are several sites that do parts catalogues for your model, try Zap 7 or failing that your local car parts centre will be able to help via the REG/VIN, TRY Carparts in motion.
I've not long picked up a set of mounts for mine. Got them from Autodoc.. circa £50 each plus postage.
Ian
Can't guarantee that yours will be on there, mine doesn't have the sensors. Worth having a look though, a very crude search just now found they do appear to stock them. You're looking at upward of £100, maybe closer to £200 each.
Ian
